February 12, 2026, 10:42:44 PM
What wire?
Topic: What wire? (Read 893 times)
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
What wire?
February 21, 2017, 08:23:52 PM »
I am running a new relay located behind the plastic cover that houses the key cam that pops off the seat and I need a ignition switched wire in this location to solder to, where best to tie in?
Re: What wire?
February 21, 2017, 09:48:41 PM »
You should get a schematic for the bike, at the back of the shop manual. Meanwhile, behind the rt cover you will see two wires bundled together with bullet connectors, green, and LtGr/red. Those are the accy terminal, fused at 5amp, G is ground, the other hot. Use it as a trigger for a relay.
Re: What wire?
February 22, 2017, 04:59:37 AM »
Quote from: MarkT on February 21, 2017, 09:48:41 PM
+1
_Sheffjs_
Sarasota FL
Re: What wire?
February 22, 2017, 05:15:00 AM »
Thanks, I have the full Honda shop manual for the 1500 (need one for the 1800c) I just knew many here could answer without thought.
Re: What wire?
February 22, 2017, 07:14:32 AM »
No. I had to get out the shop manual and look it up. Silly me.
Re: What wire?
February 22, 2017, 07:38:28 AM »
Jerry, what are you doing now?
_Sheffjs_
Sarasota FL
Re: What wire?
Reply #6 on:
February 22, 2017, 09:48:24 AM »
John, adding a Show Chrome Contour Lightbar to the 2003, the relay and wire/toggle are all neatly tucked in and zip tied in place, everything soldered and I just needed the ignition low current hot to the relay.
Last Edit: February 22, 2017, 09:54:10 AM by _Sheffjs_
