February 12, 2026, 10:43:03 PM *
Author Topic: dry clutch mc rebuilt it lever wont touch grip  (Read 791 times)
mudausasix
« on: February 27, 2017, 08:35:08 PM »
1998 Toured clutch MC ran dry rebuilt it tried to bleed it mitt vac all I get is air reversed bleed to MC opened up banjo bolt pump lever then then lever goes all the way after 4/5 pumps of lever it will not touch grip please help and advise
Harryc
Sebastian, Fl
« Reply #1 on: February 28, 2017, 01:24:40 AM »
Check the brake fluid return port in the master cylinder. It is a tiny pinhole inside a small depression at the bottom of the reservoir and it can get clogged.
« Last Edit: February 28, 2017, 01:26:34 AM by Harryc » Logged
