February 12, 2026, 10:41:49 PM
Lights, Elec. Guros question
Topic: Lights, Elec. Guros question (Read 819 times)
BigM
March 05, 2017, 04:08:47 PM »
Wired 2- 54 watt led bar type lights to frt. of bike. Used a relay fused from battery. Not through ignition, lights, or etc. When i turn the lights on my f.m. radio reception weakens. Turn them off and the station strength increases. from what I can tell these pull around 5 amps ea. I figured that wouldn't be enough to affect anything. Also will this affect my alternator/ Here is the link for the lights. Any ideas? Thanks
http://www.ebay.com/itm/112030606660?_trksid=p2060353.m2763.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Blackduck
West Australia
Re: Lights, Elec. Guros question
March 05, 2017, 05:05:29 PM »
The current draw is basically nothing to these, I run twin 100 watt driving lights.
What did you do for the ground on the lights? I run all accessory grounds back to the battery.
Cheers Steve
Itinifni
Boston
March 05, 2017, 06:33:46 PM »
Also make sure your light wiring, particularly the power supply is not routed close and parallel to your antenna feeder cable.
73? CT70
79 CB750K
82 GL1100
94 CBR1000F
Kid
Kid
97 Valkyrie Std. (May surpass the GL1100 as the best bike I've ever owned, I'll update in 50k miles)
