February 12, 2026, 10:44:44 PM *
Author Topic: Shifter Seal  (Read 1150 times)
Jruby38
Oxford Mass.
« on: March 06, 2017, 01:46:34 PM »
Do I have to drain the oil when changing the shifter seal?
Daniel Meyer
The State of confusion.
« Reply #1 on: March 06, 2017, 02:46:53 PM »
No.
http://lifeisaroad.com/valkshiftseal.html
CUAgain,
Daniel Meyer
NewValker
VRCC# 36356
Oxford, MA
« Reply #2 on: March 06, 2017, 04:37:42 PM »
Pretty easy job Matt, did mine last week.
If you need a hand let me know.
Craig
Turns out not what or where,
« Reply #3 on: March 06, 2017, 05:19:17 PM »
Easiest job you can do other than an oil change cooldude
Savago
Brentwood - CA
« Reply #4 on: March 06, 2017, 05:48:29 PM »
In case you are a visual learner (like me):
https://goo.gl/photos/e2RQb1TfPGUmJgv97
Tourus
Spring Hill, fl
« Reply #5 on: March 06, 2017, 06:38:06 PM »
   I ask the same question before doing mine and as always the guys helped out with great advise. Seems like there was a youtube video showing exactly how or a post with pictures using a screw to remove it, I used a dental pick and it came out easy. Removed the footpeg as suggested and that made it easier to remove shifter. Took me longer to clean area around seal where oil had leaked than to do the whole job but that's because I'm kind of anal and used long Qtips to get every spec. crazy2
« Reply #6 on: March 06, 2017, 07:15:18 PM »
Yep used a dental pick to remove mine and I didn't remove the foot peg . Took about ten minutes total.
If it is leaking sit probably is NOT seated so it will be easy to remove.
