February 13, 2026, 12:45:27 AM *
Author Topic: Wheel Bearings  (Read 1359 times)
dancnman
Houston, Texas
« on: March 13, 2017, 11:16:05 AM »
Am I reading this right about wheel bearings?
Front takes 2 Front, 6204-2RS
Rear takes 1 each of left rear 6204-2RS and 1 each of 5204
Reality is that thing which does not change simply because I choose to ignore it.
« Reply #1 on: March 13, 2017, 05:59:34 PM »
That's correct provided you have a '98 - '03. The '97 front wheel bearings were a bit smaller.
« Reply #2 on: March 13, 2017, 06:20:56 PM »
Moreover, valk wheel bearings are fairly standard; that is, if you have the sizes written down, any place with bearings will have them.
I would avoid Chinese.
ridingron
Orlando
« Reply #3 on: March 15, 2017, 06:14:02 PM »
If you do find yourself with Chinese bearings at least peel the seal out and grease them. Every Chinese bearing I have seen had little to no grease in them. Why ??? cheaper, hazard to ship ($$$) don't know why
« Reply #4 on: March 15, 2017, 07:01:40 PM »
http://www.jkozloski.com/generic_parts.htm
RainMaker
Arlington, TX
« Reply #5 on: March 16, 2017, 12:09:40 PM »
There is a modification you can make to the rear wheel to use only 5204 double row bearings.  I've done this to my Interstate and others in the DFW area have done this as well.  The 6204 left bearing is the one that most frequently fails so this mod was born.
This article is from shop talk
http://www.valkyrieriders.com/shoptalk/5204_bearing_mod.pdf
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
Brian
Monroe, NC
« Reply #6 on: March 23, 2017, 03:22:04 AM »
I too have done this mod when going over to the darkside. No problem to date.
