February 13, 2026, 12:46:27 AM
shifter rubber
Topic: shifter rubber (Read 1261 times)
shifter rubber
March 18, 2017, 02:31:47 PM »
Noticed I have some chunks of rubber missing on the shifter peg. Any replacement or buy the whole shifter assembly?
Harryc
Sebastian, Fl
Re: shifter rubber
March 18, 2017, 02:51:30 PM »
Part # 24781-KR3-770. It's only a couple of bucks. This is for a '97 Tourer.
http://www.partzilla.com/parts/search/Honda/Motorcycle/1997/GL1500CT+A/PEDAL/parts.html
http://s724.photobucket.com/user/Harryc56/slideshow/Valkyrie
Re: shifter rubber
March 18, 2017, 02:57:40 PM »
I need a couple of those.
The electrical tape ain't cutting it.
six2go #152
Ft. Wayne, IN
Re: shifter rubber
March 18, 2017, 03:47:15 PM »
Quote from: fudgie on March 18, 2017, 02:31:47 PM
Fudgie, I had the same thing happen on my '98. I found a replacement at Lake City.............oh yeah, there was an F6B attached to it.
Re: shifter rubber
March 18, 2017, 08:53:10 PM »
Quote from: six2go #152 on March 18, 2017, 03:47:15 PM
Re: shifter rubber
March 19, 2017, 08:37:06 PM »
Check on BigBF's website on how to modify the shifter to use any aftermarket shifter peg with a bolt on peg.
Psychotic Bovine
New Haven, Indianner
Re: shifter rubber
Reply #6 on:
March 19, 2017, 10:38:34 PM »
My brother drilled and tapped mine (after cutting off the shifter peg) and fitted a Kuryakin piece.
"I aim to misbehave."
Re: shifter rubber
Reply #7 on:
March 23, 2017, 06:14:22 PM »
On my 97 it has the rubber ( cut down in length ) off my 2010 Street glide
Brian
Monroe, NC
Re: shifter rubber
Reply #8 on:
March 28, 2017, 03:18:46 AM »
If you can get it to slide off with the help of some soap, turn it around putting the bad end toward the engine. I still ended up replacing it.
Re: shifter rubber
Reply #9 on:
March 28, 2017, 08:05:13 AM »
always safer with a rubber.
