February 13, 2026, 07:06:05 AM *
Author Topic: Low RPM Stumble  (Read 1081 times)
michaelyoung254
Huntsville, Texas
« on: March 19, 2017, 06:20:45 PM »
Noticed a bit of a glitch on my 98 Standard that maybe y'all can help me with. She seems to have a bit of a low rpm stumble. It is most noticeable whenever accelerating from a low rpm in 2nd gear. at about 1500 rpm, and wide open throttle, at first all seems normal, but when she gets to about 3000 to 3500 rpm, she starts to stumble. Not real bad, but definitely noticeable. She pulls through this, and at about a 4000 rpm, it's no longer or at least it's no longer noticeable. She has been ridden some, but due to our typical South Texas monsoon winter (rather than cold temperatures), not as much as I'd like. A couple of other things I noticed that may apply. First, when running through the gears hard (WOT), I noticed or at least I think I can smell gas, and my gas mileage seems to have dropped by a couple of miles to the gallon. I put in a can of Seafoam, and after a little over 100 miles it doesn't seem to have helped yet. Not sure where to start looking.
1998 Standard - Pearl Sedona Red & Ivory Cream
« Reply #1 on: March 19, 2017, 06:45:21 PM »
After you run the seafoam thru try Berryman's B-12 or Techron for a tank or two.  Sounds like you could have a slow jet clog.
Have you had the carbs synced ever?
The gas smell could be the fuel rails seeping if she sat for a while, but most times they swell back up.  Any trace of gas around the carbs?
michaelyoung254
Huntsville, Texas
« Reply #2 on: March 19, 2017, 07:05:34 PM »
I haven't had the carbs sychronized yet. I sure wish I could afford one of those Digi Syncs. I'll try the Techron, and the Berryman's for a couple more tanks. Hopefully that will take care of it.
« Reply #3 on: March 19, 2017, 08:21:20 PM »
I recently purchased a '97 that idled badly. It took 6-7 tanks of fuel with Seafoam and B-12 to get it to smooth out. Have patience with the carb cleaners.
Roadog
« Reply #4 on: March 20, 2017, 03:52:30 PM »
  'stumbles'  are mostly a lean condition.  Yes I agree pilot jet most likely stopped up, an easy fix.
Ride safe
Roadog
kodiakfisher
Beaverton, OR
« Reply #5 on: March 20, 2017, 05:14:22 PM »
I had this exact issue and tried seafoam and berrymans both didn't change the slight stumble around 3k RPM. A carb sync fixed it. I think at about 3k RPM you are transitioning from low speed circuit to high speed circuit in the carbs hence slight stumble if carbs are not perfect. I picked up about 10% in MPG's after doing the sync.
Doug E. on the Valky
