July 11, 2025, 05:41:02 PM
tourer & interstate CDI
Topic: tourer & interstate CDI (Read 1866 times)
triumph 69
Bean Station TN.
October 12, 2009, 07:54:57 PM »
will using the cdi box from a interstate on my tourer make a noticeable difference in my bike or is it worth the
trouble, thanks keith
ride it like you stole it
02 triumph america 99 valkyrie 02 roadstar
69 triumph bonnville 89 goldwing
F-106
Re: tourer & interstate CDI
October 12, 2009, 09:57:24 PM »
I did it about 6 months ago. Got a good deal from Kingbee here on the board. My results were positive. However not right off the bat. It took 2-3 tankfulls to get the results i noticed witch i still dont know why. That being said, over the summer i compared my mileage notes and overall i got 1-2mpg better in town and 2-4 on the highway at speeds 65-70mph. Lowend preformance improved enough to notice. If had to do it again i would however, i would get a used unit from a reliable source before i would buy new. Hopes this helps.
Duey
Rochester, MN
Use the IS CDI & throttle springs.. a 4 dgree wheel or the ECT mod in Shop Talk.
October 13, 2009, 11:22:59 AM »
triumph 69
Bean Station TN.
October 14, 2009, 04:36:12 AM »
thanks for your replys on this
Mr.BubblesVRCCDS0008
October 14, 2009, 11:17:53 AM »
Change the springs(carb) over to the interstate springs for a quick power incease. Cheap modification for about 15 bucks.
triumph 69
Bean Station TN.
October 15, 2009, 04:09:36 PM »
do I need to use 93 octane with the interstate cdI I use 89 now or will it make a difference in the bike.
F-106
Reply #6 on:
October 15, 2009, 05:02:55 PM »
i dont think it matters. i use 91 octang. few cents more you go first class. i do notice a differance with the higher grade but that may be due to the overrefined fuel we have here. i would start with 87, run a few tanks and see. check you mileage and then move up to the next grade and do the same thing. hope this helps
John U.
Southern Delaware
Reply #7 on:
October 15, 2009, 06:50:30 PM »
Unless you have a trigger wheel of have done the ECT mod, either of which will advance your timing, you shouldn't need 91 octane. I have done the ECT mod on my standard and just to be safe I run mid-grade.
triumph 69
Bean Station TN.
Reply #8 on:
October 16, 2009, 05:01:03 AM »
thanks guys
=> InZane XXV
