February 13, 2026, 12:45:29 AM *
Author Topic: Question about Shock Bushing  (Read 895 times)
Old Geezer Richard
San Antonio , Tx
« on: March 21, 2017, 10:56:41 AM »
What kind of symptoms will have when the shock bushing need to be replaced ??  I noticed a kind of a wiggle when I go into a slow curve and the road has some up and down dips in the road , there's no noise or anything just that slight wiggle ....
« Reply #1 on: March 21, 2017, 11:19:24 AM »
To check them, you have to eyeball them.  But if they are worn or out of round, the capture nut and washer may hide the damage, so pull them off and look.  Sometime you can see they're crooked even with the mounts on, sometimes you can't.
Most wiggles are tire related, but your bushings can also cause it.
Better than rubber.
http://www.xf6-custom.com/partpages/bushings.html
« Last Edit: March 21, 2017, 11:21:49 AM by Jess from VA » Logged
« Reply #2 on: March 21, 2017, 02:17:58 PM »
My first indication of a problem was a head shake coming down an off ramp near my casa. I blissfully ignored it the first 2 times. Came off the same ramp a bit faster and Almost turned into a tank slapper.  Lips Sealed NOT good by any stretch of the magination!  uglystupid2 I've just taken to put a new set in at my service on the rear end.  cooldude RIDE SAFE.
« Reply #3 on: March 21, 2017, 04:58:29 PM »
Sounds like the symptoms I experienced with worn shock bushings. Along with the ones that Jess linked from xf6, the green ones from Honda for the VTX are very good also.
