February 13, 2026, 12:45:31 AM *
Author Topic: Petcock rebuild  (Read 821 times)
keithi
« on: March 23, 2017, 07:40:04 PM »
In case anyone wonders what's inside.....!  I had gas leak by and puddle under the trike. Investigating I took the petcock apart to check the diaphragm and it looked good, seemed to operate correctly. I start looking into the hole and notice some black "stuff" inside. Kept tapping and eventually got some gunk out, looked like some type of seal. So thinking I need a new petcock I decided to do some surgery. Drilled out the rivets and took the cover plate off and checked out what was going on. I think I might be able to fix this, maybe uglystupid2. So I tapped my drilled out holes to M4 x 0.7 because that's what fit when I got all the rivet material out of the way. Found some O rings at Lowe's that look like they will work. The package says size is #5.   You can see the lip inside the hole so I am wondering how well these will stay in place once its reassembled. Any ideas on what might secure them?  Don't know if they will stay in that groove as the thickness is slightly larger than what came out. Maybe a dab of superglue?
« Reply #1 on: March 23, 2017, 07:59:49 PM »
If I was doing this, I wouldn't. Smiley
The petcock on our bikes is a very important part in Hydro Lock prevention.
You said you need a new one, so I'd go with that and get a new OEM or a aftermarket.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #2 on: March 23, 2017, 08:06:27 PM »
I don't think that those are individual o-rings but a sheet with integral raised o-rings. Probably time for a new petcock.
So many roads, so little time
VRCC # 5258
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #3 on: March 23, 2017, 08:19:36 PM »
Great pictures of the inards of a petcock.
I concur with previous posts of buying a new petcock.
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
Pete
« Reply #4 on: March 24, 2017, 06:02:23 AM »
You need the original part, the individual orings will not stay in the groove.
Yes it is one part with intergral attached  orings.
Check other petcocks as there may be one available from another petcock that will work or can be modified to work. As on some petcocks a similar part is available and replaceable.
Example look at the tank petcock for some of the V65 Hondas.
2    16958-MB4-005    GASKET    $4.16
« Last Edit: March 24, 2017, 06:06:52 AM by Pete » Logged
keithi
« Reply #5 on: March 24, 2017, 12:54:26 PM »
Thanks for the input, guys.  Just ordered my new one...
