February 13, 2026, 12:46:29 AM *
Author Topic: super valk am fm radio antenna mount  (Read 1148 times)
Eric58701
Minot NorthDakota
« on: March 24, 2017, 08:35:14 AM »
those who have the super valk kit mod , what did you do with the radio antenna? open to all options and ideas,
« Reply #1 on: March 24, 2017, 05:00:49 PM »
Check this one out.
http://www.valkyrieforum.com/bbs/index.php/topic,93105.0.html
Pete
« Reply #2 on: March 24, 2017, 07:21:02 PM »
Since I swapped out the fender struts for a standard and mounted a passenger back rest it was easy using aluminum angle to make a bracket that attaches to the 2 backrest bolts on the right side.
Used the chrome cover to cover the mount and mount the antenna.
I did angle the antenna the same as the backrest.
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #3 on: March 25, 2017, 02:36:26 AM »
I just  put a 12v powered antenna with double back sticky tape on it and stick it inside the fairing
http://www.protuninglab.com/12vamfmhianc.html?id=56128534817
