February 13, 2026, 12:45:28 AM *
Author Topic: Side Stand Extension for Dark Side, low cost fix.  (Read 4983 times)
« on: March 24, 2017, 07:10:39 PM »
Installed a 1/2" wire/cable rope clamp without the saddle clamp. Used lock-nuts and just tightened them.  fits nice and tight on the side stand.
« Last Edit: March 24, 2017, 07:17:46 PM by 98valk (aka CA) » Logged
« Reply #1 on: March 25, 2017, 07:57:13 AM »
A good innovation.
I take it that it's sitting on a single point, the nut. Good for hard surfaces.
Maybe add a spacer to the bottom side.
Or a flat bar with a hole throw it. Then the u bolt to hold it to the stand foot.
« Reply #2 on: March 25, 2017, 10:04:22 AM »
My interstate came with a nicely crafted  1/8" thick ducksfoot shaped piece, clamped fore and aft on the flat part of the side stand (all hardware on top).  It pushed me up just a little, and provided a bigger/fatter footprint.  It was fantastic.  I failed to check the nuts periodically for tight, and sadly one day it just disappeared.   Cry
« Reply #3 on: March 25, 2017, 11:08:20 AM »
A good innovation.
don't call it a u-bolt which is a different dimension than a cable/wire rope clamp. A 1/2" u-bolt is too large for the stand. This clamp has a very narrow bend.
