February 13, 2026, 02:10:27 AM *
Author Topic: Help.... I stripped the bolt on my left exhaust cover........  (Read 1406 times)
Gental Gaint
Houston/Richmond, Texas... For Now
« on: March 25, 2017, 06:04:32 PM »
What kind of fix is there for this.... ????? Sad Sad Sad Sad Sad Sad
Raymond Johnson
"Live Life"
Cell: 281-460-3794
I will ride with anyone... let's go....
« Reply #1 on: March 25, 2017, 06:13:15 PM »
Tap it out to a slightly larger size. That Galveston salt air is hard on bikes.  Shocked
WintrSol
Florissant, MO
« Reply #2 on: March 25, 2017, 06:35:50 PM »
You could get a Heli-coil kit for that size bolt, if you want to keep the stock size. A bit more work, as you have to drill and tap it for the coil, then insert the coil.
« Reply #3 on: March 25, 2017, 06:51:54 PM »
I'm with meathead, tap it out to the next size. 30 seconds and done.
Gabriel
Near Galveston
« Reply #4 on: March 25, 2017, 08:00:44 PM »
He should be good in that area, pretty far from the coast, Galveston is about 8 miles from me.
My Bike spent 17 years in Houston (garaged), no corrosion to speak of except on the lower fork legs, which I polished.
Blackduck
West Australia
« Reply #5 on: March 26, 2017, 05:05:17 AM »
Longer bolt and nut on the inside?
phideux
« Reply #6 on: March 26, 2017, 06:43:14 AM »
You say you stripped the bolt??? Just get another bolt.
If you mean the welded on nut on the back-side of the bracket, like Blackduck said, longer bolt with a nut on it.
« Reply #7 on: March 26, 2017, 11:46:03 AM »
+1
This is what I said to myself too. Stripped the bolt? Get another. SS maybe this time.
Gental Gaint
« Reply #8 on: March 26, 2017, 08:04:56 PM »
Nope.... it's the NUT.... I will do the drill & tap thing in the morning..... thanks guys... cooldude
Raymond Johnson
"Live Life"
Cell: 281-460-3794
