February 13, 2026, 02:05:46 PM *
Author Topic: Airbox question  (Read 2042 times)
W4360
« on: March 27, 2017, 10:23:53 PM »
Had to repair a leaky carb. While reassembling the intake air box down tubes, I cant seem to get them to stay attached to the carb inlets. The air box wont set down far enough. Don't see anything blocking it. Maybe something I'm doing wrong. My son pushed down on the air box, I attach them all and tighten the neck screws and they pop off! Thinking of creating a bracket to force the box down under the adjacent frame. Any ideas are much appreciated. TY! Bob
Leathel
New Zealand
« Reply #1 on: March 27, 2017, 11:50:41 PM »
have a real good look at where it attaches to the carb, is it sitting down fully all the way around, I struggled in the weekend as was sure they were on all the way around but they were held up at the back, which made it want to pop back up, A went back around and started the back first so I could see if the front went on right then it sat down without force.
 It was hard to see that it wasn't sitting on right but once it was on right it sat nicely
Blackduck
West Australia
« Reply #2 on: March 28, 2017, 04:20:55 AM »
One or more of the tubes are catching on the carb body.
They can appear to be on correctly, need to feel around them and have a good look.
Mine always sits down when tubes are correct, if it lifts I know one of them has caught on the carb lip.
No force required when all on correctly
« Reply #3 on: March 28, 2017, 05:07:38 AM »
i use a short 2x4 across the air box with a ratchet strap. I can install mine in 10 minutes with this method.  cooldude
pancho
Bonanza Arkansas
« Reply #4 on: March 28, 2017, 06:19:51 AM »
Check the front right corner/side of the airbox,, it will catch/hang on the wiring harness and prevent it seating correctly and cause the spring back.  Like Blackduck said, "No force required when all on correctly"
Fazer
« Reply #5 on: March 28, 2017, 07:27:13 AM »
Check out Dag's method.  It worked for me.
Greg
http://valkyrienorway.com/airboxinstall.html
Nothing in moderation...
« Reply #6 on: March 28, 2017, 09:32:35 AM »
Yup, been doing it that way for the last 14 years & works great, leaves both hands free to work it a bit. Put the filter in and mount the top, then place a 2x4 maybe 4-5" long on top and pull it down with a ratchet strap attached to the engine guards. As suggested, check the back of the carbs to be certain the rubber connectors aren't hung up/rolled under. If so, get a skinny shaft screwdriver and slip it under the lip of the rubber and run it around the top of the carb. That will unseat the rolled under section in back and it slips right on. Watch the harness near the front right, can also be a PITA.
« Reply #7 on: March 28, 2017, 09:55:04 AM »
It helps to have a mirror to see the back side of the connections.
Brian
Monroe, NC
« Reply #8 on: March 29, 2017, 03:36:48 AM »
A little silicone lube on the inside works great too. I used the stuff sold for rubber spark plug boots. cooldude
Solorider
Loud Pipes Save lifes, Ride alongside a Harley
New Orleans
« Reply #9 on: April 17, 2017, 09:07:43 AM »
Did it yesterday "AGAIN" One thing that helps me, I think is I use a very small amount of silicon rubbed on the neck of the airbox feet it seems to allow them to side in place easier.
My two cents
Solorider
bzane
« Reply #10 on: April 18, 2017, 12:05:44 AM »
Try wiping down the air box snorkels and carb tops with plenty of isopropyl alcohol from a drug store. Got that hint from a YouTube. Worked for me, went on real easy! (Maybe 10 minutes to makes sure well seated)
Gabriel
Near Galveston
« Reply #11 on: April 18, 2017, 06:03:51 AM »
Greg
Did you like the way the video cut away twice during the hardest part?
This is a video on how to put tie wraps on your carb boots...
KG
Munford Tennessee
« Reply #12 on: April 18, 2017, 01:19:14 PM »
a hose pick also helps
https://www.amazon.com/TruePower-21-5567-Radiator-Specialty-Insulated/dp/B0095Y17S6
What we do all have is a limited number of days to devote to whatever we love in this life.  Not all the same number of days but all have limited days....Willow
bzane
« Reply #13 on: April 20, 2017, 09:18:17 PM »
Hehe, also watched a video on desmog. Parts were in fast-forward. Fasted wrench in the west!
dchester4
NE, USA
« Reply #14 on: August 13, 2017, 02:42:44 PM »
Thanks for this thread and others like it.  There are some of out there messing with this thing for the first time.  Got everything back together!
Dan.
Ride on my friend....
