November 27, 2025, 05:13:06 PM *
Author Topic: led rear light bar for the interstate  (Read 1122 times)
Hoosiervalk
Bristol, IN
« on: March 30, 2017, 10:27:14 AM »
looking for a good light bar for under the trunk of the interstate. I would like a run, brake and turn light. the brighter the better! any suggestions?
« Reply #1 on: March 30, 2017, 11:49:55 AM »
Not a bar but look into HyperLights (maybe lites). They will attach to the bar under your trunk with all the functions you're looking for. Amazon has good prices.
« Reply #2 on: March 30, 2017, 12:24:00 PM »
Led strips (flexible or not) of all kinds.  But I think you ordinarily get run and brake, not turn.
While not as high, you can get a Back Off license plate frame with two rows of bright leds... run and brake.
There may be run brake and turn in some of those. I dunno.
I have a controller that makes my signals run, brake, AND turn (with red lenses) (just the 1156 bulbs, no leds).  Together with the led plate frame run and brake.
And I added the tourer std tail light under the trunk in the knockout, run and brake of course.  That light shows up very well since it is almost always in the shade under there, even with an 1157 bulb.  But there's a fit problem (lens to radio) if you have the CB under there.
Keep in mind with led turn signals, you will need an electronic flasher (or else they blink very fast) (this looks wrong, but on the other hand it certainly is attention grabbing, which is the whole point).  I would not use load equalizers in lieu of the electronic flasher (which get hot enough to cause trouble, and use as much power for leds, as if you were running std bulbs).
« Last Edit: March 30, 2017, 12:27:57 PM by Jess from VA » Logged
« Reply #3 on: March 30, 2017, 01:41:54 PM »
I just had the L E D modification done to my stock tail light assemblies by Bons and I AM Pleased with how bright they are.  cooldude RIDE SAFE.
Mr.BubblesVRCCDS0008
« Reply #4 on: March 30, 2017, 04:22:10 PM »
Try custom dynamics on the web. They have a lot of good lighting options. I run the large nightrider  light in both my interstates. I like the moving lights to draw attention to the bike.
KG
Munford Tennessee
« Reply #5 on: March 30, 2017, 04:24:52 PM »
Been looking at this one has turn leds also
http://www.customdynamics.com/integrated_led_light_bars.htm
What we do all have is a limited number of days to devote to whatever we love in this life.  Not all the same number of days but all have limited days....Willow
« Reply #6 on: March 30, 2017, 04:47:27 PM »
I think BonS is a dealer now for CustomDynamics products.  cooldude
Lyle Laun
Calgary, Ab
« Reply #7 on: March 30, 2017, 07:06:52 PM »
If you can find this brand and model, it will have everything you want.
 Whelen Smart LED Strip-Lite Series PSRASXCR Brake/tail light amber w turn signal.
I've got one and wired it in to the trailer plug on my Interstate
Regards
Lyle
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
ridingron
Orlando
« Reply #8 on: April 02, 2017, 03:20:08 PM »
See whelen lights at:
http://www.qualityemergencylights.com/whelen-striplite-series-led-braketail-with-amber-turn-p-2538.html
$100
Hoosiervalk
Bristol, IN
« Reply #9 on: April 03, 2017, 02:47:45 PM »
The Whelen looks like a great light bar. How did you fit it under the trunk? at 11 1/2" wide I can't see how it would fit?
SCain
Rio Rancho, NM
« Reply #10 on: April 03, 2017, 08:13:29 PM »
I've been running the small night rider, it fits perfectly on the lower trunk support, has a flashing stop then turns solid, very bright and compact.
Steve
Hoosiervalk
Bristol, IN
« Reply #11 on: April 04, 2017, 03:31:02 PM »
Thanks SCain and Mr. Bubbles, I think I would like to go with the bigger 21 led light. As I was taking a look at the valk I looked at the side bars of the trunk and how do you think having these on them would work? I would like to have some side lights too.
