November 27, 2025, 05:12:38 PM *
Author Topic: RESOLVED: Youtube video of my '97 with start/idle/poor throttle response.  (Read 1638 times)
nogrey
Nampa, Idaho
« on: April 02, 2017, 06:59:56 PM »
I've been tinkering with the tune on my '97. I've been having poor start when cold issues, poor idle issues and poor throttle response (hesitation) when going from a "coast" to a slight acceleration.  Adjusting the carb sync and pilot screw adjustments. It's never run this smooth before but wondering what others think. Watch this short youtube video and give me you opinion. I appreciate all the help those who have contributed have been. I never stop learning. Thanks so much!
https://youtu.be/77-rpjiXyo0
RESOLVED! Loose timing belts, small vacuum leak and valves needed adjusted. It's a different bike now!
« Last Edit: April 10, 2017, 06:51:52 PM by nogrey » Logged
« Reply #1 on: April 02, 2017, 07:18:35 PM »
It seemed to be idling smooth as best I could tell from the video. But I'm curious about the smoke from the right side ? Or was it just water vapor from the air being cold ?
nogrey
Nampa, Idaho
« Reply #2 on: April 02, 2017, 08:52:35 PM »
Seemed to be more from the right stack than the left, but it wasn't quite to operating temp.
« Reply #3 on: April 03, 2017, 04:04:49 AM »
Sounds normal to me cooldude
mrtlc
Elroy WI
« Reply #4 on: April 03, 2017, 04:13:25 PM »
Time to get the Nickels out  Smiley
99 Interstate 1500
89 Goldwing sidecar 1500
88 Goldwing 1500
85 Goldwing 1200
84 Gold wing 1200
80 Goldwing 1100
79 Yamaha XT500
78 Honda 750K
nogrey
Nampa, Idaho
« Reply #5 on: April 03, 2017, 07:10:26 PM »
Still doesn't seem quite right. Gotta fix it somehow.
phideux
« Reply #6 on: April 04, 2017, 10:20:15 PM »
I think the #2 carb is running too rich, turn it out about 1/64th of a turn and take about a 16th of a pound of air out of your back tire, Should run purrfect then.
nogrey
Nampa, Idaho
« Reply #7 on: April 05, 2017, 06:34:01 AM »
OK, I did that. Turns out it only needed 1/128th of a turn and I had to add 1/132nd lb in the front tire. Working good now.
« Reply #8 on: April 05, 2017, 11:04:26 PM »
Not only does it sound good, it looks great too.   cooldude
« Reply #9 on: April 07, 2017, 07:46:53 AM »
is fine, get out and drive it now.
am sure my Valk is 80% tuned up nothing done to it, is still better than 95% of v-twins running today.
I chased down yesterday a nice looking newer 20K+ HD yesterday but backed off since doing 80 in a 55 do not want to get a speeding ticket so early in the riding season.  Ran good enough for me even though I know the Valk needs a tweaking or two am sure.
nogrey
Nampa, Idaho
« Reply #10 on: April 07, 2017, 11:44:12 AM »
I was still not happy with it. I tore down the carbs and found that every single float valve was bad. So I cleaned all the carbs, installed new gaskets, replaced the 38 jets with 35's, found 1 cracked and leaking air cutoff valve hose and replaced all the cutoff valve hoses. Adjusted the pilot screws to 2-1/4 out, reinstalled the carbs, synchronized them with the digi-sync, and she seems to purr now. Had to go to work so haven't had a chance to ride it yet. We'll see.
