November 27, 2025, 05:13:07 PM *
Author Topic: Clutch replacement, OEM, Barnett or other?  (Read 1220 times)
NEHI
« on: April 06, 2017, 12:12:55 PM »
      I have got the engine out of my 93 Goldwing trike with 73k on it. I have the clutch apart and it looks good and measures out OK, but it's also 25yrs old. So while I am into it I am going to replace it. Any opinion on brands?
« Reply #1 on: April 06, 2017, 05:29:25 PM »
OEM. all Goldwing GL1500 clutches were upgraded in '97 and are the same as valkyrie clutches. what the changes were are a few disks were not the better paper type  as all the others were. '97+ they are all paper. OEM are good for at least 300k miles. u can get a complete OEM set cheap on ebay. Barret are same paper material any other material is lower quality.
Jruby38
Oxford Mass.
« Reply #2 on: April 07, 2017, 01:26:42 PM »
I have a Barnett  for 90k miles Love it , but he clutch lever is stiffer than OEM. Just go to neutral at stop lights.
Savago
Brentwood - CA
« Reply #3 on: April 07, 2017, 02:42:08 PM »
+1 on OEM (if you divide the price by expected miles, it is dirty cheap).
Hooter
S.W. Michigan
« Reply #4 on: April 08, 2017, 05:35:17 PM »
OEM..this one lasted 73000 so why not think the OEM replacement would be any different?
« Reply #5 on: April 08, 2017, 06:24:10 PM »
the stiffer clutch lever is due to the barnett clutch spring which is known to be stronger than the OEM. supercharged bikes were using that or two OEMs.
