November 27, 2025, 05:13:08 PM *
Author Topic: Parking support  (Read 1752 times)
Relax
Power & elegance...just like the Valk
Oslo, Norway
« on: April 08, 2017, 12:57:24 AM »
Smiley
I now and then would like a kinda support to my Valk ( standard 2001) to keep it straiht up, f inst during oil draining, washing and other stuff..
I do have a lift etc...but I am looking for a more  easy / quicker solution...
What do you do?
Harryc
Sebastian, Fl
« Reply #1 on: April 08, 2017, 02:55:37 AM »
Here's my solution. I keep it on the floor of the garage and ready at all times.  It's 'very' stable, quick, and easy. It takes a bit of a pull to get the bike out of the stand but not bad.  Also it works much better if you have a rubber mat under it that the motorcycle also sits on. If you don't do that it tends to slide unless you also anchor it.
http://www.harborfreight.com/1800-lb-capacity-motorcycle-standwheel-chock-61670.html
« Last Edit: April 08, 2017, 04:49:31 AM by Harryc » Logged
« Reply #2 on: April 08, 2017, 04:08:13 AM »
Here's my solution. I keep it on the floor of the garage and ready at all times.  It's 'very' stable, quick, and easy. It takes a bit of a pull to get it out of the stand but not bad.  Also it works much better if you have a rubber mat under it that the motorcycle also sits on.
Yours looks much better than my Harbor Freight chock... mine works, but I had to bolt
it to a piece of plywood, and I stretched it out because it pinched the snot out of my
front tire...
Chocks are great for the OP's purposes...
oldsmokey
Mendon Massachusetts
« Reply #3 on: April 08, 2017, 07:32:13 AM »
I use the Condor. Certainly not HF pricing.  All aluminum. Works great for trailering, driveway and garage. FYI: On polished concrete the bike will push it even if on a mud flap uglystupid2 For departure I just squeeze front brake, pump the forks a couple of times then release on final pull back.
« Last Edit: April 08, 2017, 07:35:41 AM by oldsmokey » Logged
« Reply #4 on: April 08, 2017, 08:27:38 AM »
I got a condor for the black bike...
It seems functionally equivalent to the Harbor Freight one, even though the
Harbor Freight one is stamped steel and the Condor one is made from
awesome sauce...
In my crappy Harbor Freight picture, you can see I have a large slab of half inch
thick steel... I think it weighs about 50 tons  Roll Eyes ... I put my chocks up against
that 1/2 inch lip of immovable steel and the bikes just roll right onto the chocks
with no chock slipage...
Jopson
Egan SD
« Reply #5 on: April 08, 2017, 09:28:17 AM »
Axle stand under right side crash bar, 2inch block of wood under kickstand.
Roadog
« Reply #6 on: April 08, 2017, 10:05:19 AM »
  Center stand.
Roadog
indybobm
Franklin, Indiana VRCC # 5258
« Reply #7 on: April 08, 2017, 12:44:45 PM »
Mount the wheel chock to a 4 x 8 piece of plywood. When you are putting the front tire into or out of the chock, the back tire is on the plywood. Chock will not move.
So many roads, so little time
VRCC # 5258
« Reply #8 on: April 08, 2017, 07:57:05 PM »
This is easy and gets the bike straighter than my chock
« Reply #9 on: April 08, 2017, 08:12:32 PM »
I have the Harbor Freight unit, the heavy one. To keep it from sliding I just lay a couple 35lb. dumbells across the outer braces. Takes a could grunt to pull it out but works fine for my purposes if I don't need to lift the bike. I also have a centerstand so seldom use a lift except to work on the front wheel.
Bugslayer
Lubbock, Texas
« Reply #10 on: April 08, 2017, 10:13:28 PM »
My neighbor had some scrap steel. He put this together for me..... Works great. I also use it in the back of the truck for my dirt bike.
Relax
Oslo, Norway
« Reply #11 on: April 08, 2017, 10:39:40 PM »
Thanks guys cooldude
The ones in steel looks pro, but the solution in block of wood is a very wuick fix and will do the trick!
Thanks!
 Smiley
Savago
Brentwood - CA
« Reply #12 on: April 09, 2017, 12:34:41 AM »
I use one of those Harbor freight stands + jack stands on each side of the engine guard:
https://goo.gl/photos/1NTFshTEQ8ZipGEz7
The jack stands cost around 19 bucks for a pair on Amazon (adjustable and supposedly good for 6000lbs):
https://www.amazon.com/gp/product/B000760FX4/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Bone
« Reply #13 on: April 09, 2017, 03:45:43 AM »
Chrisj I like the idea do you lift with the jack to insert the supports ?
« Reply #14 on: April 09, 2017, 04:34:35 AM »
No the whole point is to not need the lift. While leaning on the side stand I position the right side stand. Then right the bike and slip the left one under the crash bar. Just make sure the bike is in gear so it can't roll off the stands.
Stands are 12" high before cutting a nitch about a half inch deep for the catch bars to rest in.
Bone
« Reply #15 on: April 09, 2017, 08:08:17 AM »
Thanks Chris that's why I asked I imagined it could be done by tilting the bike a bit.
I'm going to try a similar pair.
