February 13, 2026, 02:57:14 AM *
Author Topic: Bearing Part Number  (Read 1018 times)
dancnman
Houston, Texas
« on: April 09, 2017, 06:07:05 AM »
Anyone have the part numbers that parts houses (NAPA, Advance, etc) use for the 5204 2rs and the 6204 2rs bearings?
Reality is that thing which does not change simply because I choose to ignore it.
« Reply #1 on: April 09, 2017, 06:46:55 AM »
Search for a bearing/belt supply house for industry. Houston is a large town and should have a store. Here in PHX we have "Bearing Belt and Chain".
« Reply #2 on: April 09, 2017, 07:28:57 AM »
I think you just walk in and ask for a 5204...
Type "5204 bearing" into google and hits will flow out like water under
pressure from a four inch pipe...
Blackduck
West Australia
« Reply #3 on: April 09, 2017, 08:18:47 AM »
Those numbers will get you what you want at any decent bearing supply.
Does not matter who made them they all use the same sizing.
Definitely want the 2RS and not ZZ
RS is seals while ZZ are shields and they don't fully seal
« Reply #4 on: April 09, 2017, 09:09:13 AM »
Yes, and so do you.  Smiley
But the suffix shows the rest of the story, as Blackduck pointed out. You want dual seals.
Have you researched the dual bearing mod?
http://www.valkyrieriders.com/shoptalk/5204_bearing_mod.pdf
« Reply #5 on: April 10, 2017, 10:22:24 AM »
I printed this out and laminated the sheets. They travel with me in the left saddlebag with tools etc.
http://www.jkozloski.com/generic_parts.htm
dancnman
Houston, Texas
« Reply #6 on: April 11, 2017, 10:18:58 AM »
I have lots of bearing supply houses to get them from and actually ordered them from Motion Industries. I think Amazon even has them.
But, I tried to get them from O'Reiley, Advance, and NAPA. None of them had a clue. That is why I asked if anyone had part numbers from the parts houses. Some people seemed to get them from NAPA etc.
Thanks for all the help from everyone.
