February 13, 2026, 02:51:40 AM *
Author Topic: Rear Wheel / right side oil splatter  (Read 2132 times)
verngroves
Central New York
« on: April 10, 2017, 02:22:33 PM »
I have a 2000 Standard just turned 70,000 miles. I have what look like oil splatter on the rear rim. Any clues as to how to fix? I'm not the best mechanic but I am teachable. I've learned a bunch from you folks. And I've tackled things I never would have before. So thanks.
Thanks in advance.
Vern
Leathel
New Zealand
« Reply #1 on: April 10, 2017, 03:00:08 PM »
Is there any sign of oil coming out the final drive vent?
I had that on my shadow so replaced the oil with synthetic and no more issue Smiley
indybobm
Franklin, Indiana VRCC # 5258
« Reply #2 on: April 10, 2017, 03:03:29 PM »
Have you done anything around the rear wheel lately?
So many roads, so little time
VRCC # 5258
Beardo
Regina, Saskatchewan Canada
« Reply #3 on: April 10, 2017, 03:53:28 PM »
Mine was leaking out the bottom of the final drive, there's a seal in there that you can replace if that's it. It's easy to replace but you have to remove the rear wheel to get to it. It's like a $10 seal.
« Reply #4 on: April 10, 2017, 04:38:37 PM »
Simple things first.  Check oil level in final drive and make sure the fill and drain plugs are not loose and leaking.
verngroves
Central New York
« Reply #5 on: April 10, 2017, 05:27:41 PM »
Hopefully have a chance sometime tomorrow evening to check out some of your suggestions. Thanks for all your responses.
« Reply #6 on: April 10, 2017, 09:42:51 PM »
It is most likely oil coming out of the grease from the splines. Clean it. When it comes back, is it less, or just as much?
Like mentioned, inspect your rear oil level. Don't over tighten the fill plug.
verngroves
Central New York
« Reply #7 on: April 11, 2017, 09:39:23 AM »
Well, I looked at the fluid level. I took off the cap and stuck my finger in there and the level was right there....not overfull. But looking underneath the final gear case the bottom was covered with oil. And the bottom of the whatever you call the black band is also got oil on it. So, it looks as though it's coming from there.
I'm thinking the seal that was mentioned. If I pull the wheel, what's the procedure to get to that seal or o ring?
« Last Edit: April 11, 2017, 09:44:38 AM by verngroves » Logged
« Reply #8 on: April 11, 2017, 09:58:10 AM »
Here's the seal, it is easy to replace... if it is your problem, I
guess it will be pretty obvious that the oil is coming from there
when you can see the backside of it like this:
The black ring comes off with just that one bolt, I had mine off this
weekend, makes it easy to get everything clean before you put it
back together...
The seal should be this thing, about 10 dollars: 91265-MY3-003
Beardo
« Reply #9 on: April 11, 2017, 10:14:57 AM »
You can replace the seal just by taking off the wheel, you don't have to fully remove the final drive. Having a lift would make it much easier. But if you don't have a lift, or if you haven't checked/greased your driveshaft and pinion cup in a while, you might as well undo the 4 final drive bolts and do the full service.
You'll want to also replace the 3 o-rings and grease your splines while you're in there. Shoptalk section has all the info you need to do that.
Getting the old seal out, you can screw a screw into it and pull it out. Make sure you just put the new one in flush, not too far. I was warned of this when I did mine.
« Last Edit: April 11, 2017, 10:17:22 AM by Beardo » Logged
« Reply #10 on: April 11, 2017, 02:03:01 PM »
grease is oil held on suspension. under certain conditions and during normal use the oil will come out of the spline grease and drip down.
simple test. smell the oil. does it smell like gear oil, then u know its the seal. If not then its the spline grease.
verngroves
Central New York
« Reply #11 on: April 11, 2017, 02:47:15 PM »
What are the 'certain conditions' that oil will come out of the spline grease and drip down? I don't quite get that.
« Reply #12 on: April 11, 2017, 03:20:38 PM »
too much was applied during installation.
grease doing its job, letting oil out to lubricate due to excessive heat under certain operational conditions. overloaded, pulling a trailer, up a mountain during high ambient temps, any combination of these.
« Reply #13 on: April 11, 2017, 03:23:09 PM »
After you shmooie up the flange with moly-paste, it can fling out. I guess
if you went way overboard, it could fling out and get on your wheel. I can't
see it happening except for right after putting it in there though... ?
indybobm
« Reply #14 on: April 11, 2017, 04:40:35 PM »
Just curious, when you checked the oil level, was the bike on the side stand? It should be at the bottom of the threads with the bike standing straight up.
VRCC # 5258
Valker
Wahoo!!!!
Texas Panhandle
« Reply #15 on: April 11, 2017, 05:01:45 PM »
Which cap?
Valkpilot
What does the data say?
Corinth, Texas
« Reply #16 on: April 11, 2017, 07:25:14 PM »
back together...
If and when you replace that seal, do not push it in past flush with the case.  It will leak if you do.  It actually should sit a little proud of the case, but no deeper than flush.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
verngroves
Central New York
« Reply #17 on: April 12, 2017, 09:41:42 AM »
The cap I pulled was the upper one. The one where you fill from. Also, it was pretty much up straight when I checked it. I'd placed enough lift under the kickstand to make that happen.
I've wiped it all down and will ride it again whenever the weather is appropriate and get back with you all on how or if it continues to leak. If it leaks, I'll pull the real wheel off and all apart to replace at least that one seal. Probably will do all the necessary seals while I'm in there. Thanks for all your input on this project. What a great group of riders you all are. You've helped me to rise way higher on my mechanical ability than I've ever been before. These challenges are good and want to keep this baby up to snuff so that it'll last me for a long time. Maybe it'll last longer than I'll be able to ride her.
« Reply #18 on: April 12, 2017, 12:12:21 PM »
Vern with proper upkeep it will outlast you and maybe the next owner cooldude
da prez
Wilmot Wi
« Reply #19 on: April 15, 2017, 10:33:18 AM »
  Vern , old age or movement. Either one would justify going thru the rear end and doing a full service and checking the wheel bearings. When the rear tire is off , you are in the right neighbor hood to visit everyone. It beats an oops on the road. Just my .02 cents before taxes. An often overlooked issue could be the final drive vent. Not common , but if it plugs up , it will cause a pressure build up in the final drive that could cause a seal leak.
                                                            da prez
« Reply #20 on: April 15, 2017, 01:11:34 PM »
Hey Vern, It`s Ernest !...................Sorry, bet you`ve never heard that one before ?  Wink
I have had grease sling out on my wheel before. Once I packed too full, once an o-ring broke. da prez is right though. You should go all in. Have you done the rear maintanence before ? If not, it`s easy.  cooldude  I`ve also had the oil on the wheel from leaking shocks.
« Last Edit: April 15, 2017, 01:13:34 PM by meathead » Logged
verngroves
Central New York
« Reply #21 on: April 16, 2017, 05:33:28 PM »
Hey Ernest, this is Vern. You guys have convinced me to get in there and do the whole rear end deal. No, I've not done the rear end. I've greased the gear each tire change, but gone no deeper. So that will have to happen....soon. The weather is breaking here and so I'd better do it soon.
So, I'll need to get all the necessary seals and o rings. From my local Honda dealer is the best way to go on getting those seals and o rings?
Thanks guys for all your help and insight. You are a fabulous resource.
« Reply #22 on: April 16, 2017, 05:47:24 PM »
I like to get my o-rings from Carolina Bike & Trike. There are some good instructions in ShopTalk. And everyone here can help.  cooldude I don't know if I'd be buying up parts before you know what you need. Might just be broken o-rings slinging out grease.
« Reply #23 on: April 17, 2017, 08:40:15 PM »
Rear end service, in Shop Talk.
http://www.valkyrieriders.com/shoptalk/rear_end_service.pptx
Carolina Bike and Trike.
http://www.carolinabikeandtrike.com/company.htm
