February 13, 2026, 07:06:04 AM *
Author Topic: Replacing Vacuum Tubes  (Read 1634 times)
wellandfit
Fredericksburg TX
« on: April 14, 2017, 10:54:53 AM »
Hey Guys:  I'm needing to replace the vacuum tubes.  Any detailed tips and procedures are greatly appreciated.
« Reply #1 on: April 14, 2017, 11:02:34 AM »
Time you get the tank and airbox off why not just desmog and be done with it?  coolsmiley Then if you use the stock petcock yer down to one and Only one vacuum line.  cooldude lso while yer n the neighborhood look at the condition of the fuel lines. RIDE SAFE.
« Reply #2 on: April 14, 2017, 11:45:38 AM »
I replaced my vacuum lines from the bike to the trash.  Grin
Leathel
New Zealand
« Reply #3 on: April 14, 2017, 12:17:27 PM »
I have no vacuum lines on the bike, They are in the bin also. Manual tap and desmog done
« Reply #4 on: April 14, 2017, 03:54:01 PM »
Your best bet is OEM tubing. It's 3.5mm diameter.
nogrey
Nampa, Idaho
« Reply #5 on: April 14, 2017, 08:59:01 PM »
Really, you should desmog the bike, then buy your needed vacuum supplies from redeye.ecrater.com.
Gabriel
Near Galveston
« Reply #6 on: April 15, 2017, 03:24:30 AM »
"Vacuum tubes" It took me a little while to understand this. ???
joker
New York
« Reply #7 on: May 12, 2017, 03:25:44 AM »
Alrighty then....how does one Desmog if one was going to Desmog?
jim@98valkyrie.com
Wayne, PA
« Reply #8 on: May 12, 2017, 03:58:11 AM »
That was my first thought too. Before I opened the thread, there were mental images of taking the suspect tube down to the local joint that had a tester and a cabinet full of new vacuum tubes.
h13man
Indiana NW Central Flatlands
« Reply #9 on: May 13, 2017, 05:25:13 AM »
[/quote]
Damn I'm old. I remember my dad taking tubes to the local hardware store and checking them. "Those were the days my friend we thought they never end..."
Icelander
Snohomish, WA
« Reply #10 on: May 13, 2017, 05:50:29 AM »
There's a couple of desmog posts on the ShopTalk portion of the website:
http://www.valkyrieriders.com/shoptalk/desmog.htm
and
http://www.valkyrieriders.com/shoptalk/smog.htm
Red Eye has desmog kits that you can use to make it even cleaner, but it's not necessary.
Rather than modify/remove the exhaust port tubes, I just capped them off. Keeps the look stock and doesn't require any extra work.
Good luck my friend.
Icelander
1998 Valkyrie Tourer.
VRCC Member #36337
