March 15, 2026, 08:21:40 PM
Florida Chapter
Bad noise****UP DATE***
Topic: Bad noise****UP DATE*** (Read 1702 times)
firemedic309
Sarasota. FL....Nancy Ky
April 18, 2017, 10:07:09 AM »
Ok so I went riding today did about a hundred and twenty miles to bike did great. I pulled into the national cemetery in Sarasota County made a loop around everything was still going fine. All the sudden my bike starts making a terrible squeaking grinding noise from the rear. Did my final drive go out? Wheel bearing? Looking at taking it to the shop on a trailer any hot ideas. posted on tec board and had some helpful reply's. I am in Sarasota and need some help with it. Who should I use? Thanks
Randy Schultz (firemedic309) 941-374-0756
*****UPDATE...... went to Grumpys today and it was the skinny bearing that was shot. Thanks to Grumpy the bike is all serviced and up and running right!
Last Edit: April 24, 2017, 12:23:45 PM by firemedic309
Remember, if they can't find you handsome at least they can find you handy!
Bronxboy
Tampa Bay FL
Re: Bad noise
April 18, 2017, 11:18:02 AM »
I would at the very least, take the rear wheel off and inspect all the obvious parts of the drive line and bearings. Once u have done that, and u still cant find the problem, then it would be time to get it to someone with knowledge of our Valks.
Not sure about anyone down in Sarasota, but Grumpy is up in the Tampa area?
https://photos.app.goo.gl/Z8XVCYBWHGEvRSvL2
firemedic309
Re: Bad noise
April 18, 2017, 11:23:52 AM »
Bert AKA,Valkaholic
Back-N-Black
Re: Bad noise
April 18, 2017, 12:04:51 PM »
I Second That You Look Up "Grumpy", Bill Gurney , Here On The Florida Board !
firemedic309
Re: Bad noise****UP DATE***
April 24, 2017, 03:03:09 PM »
