February 13, 2026, 05:06:57 AM *
Author Topic: 98 standard rear shocks  (Read 887 times)
Roidfingers
Tuscaloosa, Alabama
« on: April 22, 2017, 06:46:46 PM »
Ok, I want to stiffen the ride a little the PO was a little guy and I'm about 70 more then him. The stickers are missing on the OEM shocks and not sure what they are set at. I will lift the bike and want to adjust to highest level to start with. How do I know what is 1, 2, etc?
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: April 22, 2017, 08:35:31 PM »
Turn them until it BANGS loudy, now they are at "1".
Roidfingers
Tuscaloosa, Alabama
« Reply #2 on: April 23, 2017, 05:27:06 AM »
If I'm facing the shock from the side of the bike. Do I turn from right to left or visa versa?
« Reply #3 on: April 23, 2017, 05:30:03 AM »
Right to left.
Harryc
Sebastian, Fl
« Reply #4 on: April 23, 2017, 07:31:55 AM »
...or clockwise looking down at the top of the shock. I won't tell others what to do, but for me 'banging down' the shock from the highest setting to lowest can't be a good thing for the shock. Also you can turn it counter-clockwise as long as it is not on position #1. I guess if you don't have any numbers you can't avoid banging it down once. Suggestion, once you find position #1 mark it with a sharpie. Make your own arrows or numbers for the other positions. Position #1 will be the first position after the 'bang down'. i am pretty sure I read in the manual not to go from position 5 to 1 (bang down) as well....but oh well.
« Last Edit: April 23, 2017, 07:35:51 AM by Harryc » Logged
Roidfingers
Tuscaloosa, Alabama
« Reply #5 on: April 23, 2017, 09:48:56 AM »
Thanks for the help. Lifted the bike. Easy turn by hand, Done.  cooldude
