March 15, 2026, 08:21:08 PM *
Author Topic: Added tail light on interstate and need electrical help  (Read 1666 times)
farmer998
New Smyrna Beach Fl
« on: April 26, 2017, 05:25:44 PM »
I can use a little help with an electrical question.  I added a tail light with the Radiantz insert to the interstate to add some needed light to the back.  Question is...were do I tie it in?  I am no electrical wiz but can do as instructed(picture would help).  I am willing to drive it to someone if they can show me.  Any help would be appreciate
Thank you in advance
Randy
Grumpy
Tampa, Fl
« Reply #1 on: April 26, 2017, 05:29:18 PM »
under the seat on the left side of the bike, is a plastic shroud that the wires go to the stock lights. You can tie the light in there. Arrgh, right side, my bad
« Last Edit: April 27, 2017, 04:21:45 AM by Grumpy » Logged
farmer998
New Smyrna Beach Fl
« Reply #2 on: April 27, 2017, 03:49:53 AM »
OK thank you...hopefully there is a large flashing NEON arrow under there also but I will give it a try
farmer998
New Smyrna Beach Fl
« Reply #3 on: April 30, 2017, 05:37:09 PM »
Light is mounted and functional,  thanks to Grumpy.  Even though there was no neon arrow under the seat as hoped it only took 1 PM to the master and it was done.  Now if these old Floridians can't see me there is a problem.
Farside
Let's get going!
S. GA - N. FL
« Reply #4 on: April 30, 2017, 06:32:34 PM »
 Hey Farmer,
   I see you added the tail light on your IS but with the LED's you got from BOnS a few months back for your trunk why the light below? Are you looking to Super Valk your IS?  I also got the lights from BonS after I saw your post, Really Bright! coolsmiley
Farside
Bert AKA,Valkaholic
Back-N-Black
« Reply #5 on: May 03, 2017, 04:51:59 AM »
I Don't Think It's The Floridians That You Have To worry About Running Over You !
farmer998
New Smyrna Beach Fl
« Reply #6 on: May 06, 2017, 12:02:58 PM »
OK OK you're right its not the Floridians its for all my HD buddies I ride with.  They just cant keep up with the Valk so I needed more light so they could still see me from that far back.
OLDFRT
« Reply #7 on: May 06, 2017, 05:19:33 PM »
Good Answer!!!!!
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« Reply #8 on: May 06, 2017, 06:25:32 PM »
Good Answer!!!!!
I know an "old fart" that proved himself and his HD on the Dragon!   Now nicknamed SCRAPE.   cooldude
« Last Edit: May 06, 2017, 08:24:09 PM by _Sheffjs_ » Logged
