February 13, 2026, 05:07:02 AM *
Author Topic: Passenger Floor Boards  (Read 971 times)
oldsmokey
Mendon Massachusetts
« on: April 28, 2017, 09:33:28 AM »
Looking for a general consensus as to a preferred mfg of passenger floor boards for an I/S. Also realize what may be preferred may no longer be available. Factory pegs seem to be a close fit for passengers legs against saddle bag hinge. Think boards may allow a little forward movement. May also be looking for driver boards, going to try a set of M/C with toe heel first. Thanks.
« Reply #1 on: April 28, 2017, 10:14:49 AM »
Most use Cobra boards.  I do at the driver position (with heel toe shifters), not the passenger (I never take a passenger)
However, if you look at Kuryakyn products, check out the ISO Wings, which is like half a floorboard.  You have to get the specific mount piece to mount to the valk rear (or front) peg position, then the ISO WINGs (without ends) mount to that mount.  This is better than pegs, but only half to a third the cost of a set of Cobra Boards.  You can do the same thing for driver's peg replacement (with or without a heel toe shifter)
Iso wings without ends.  Go to their site to find the mounts for front and/or rear valk pegs.
At the driver position on Valk
« Last Edit: April 28, 2017, 10:17:50 AM by Jess from VA » Logged
oldsmokey
« Reply #2 on: April 28, 2017, 01:52:01 PM »
Very good. It will be part of the search process, Thanks.
Leathel
New Zealand
« Reply #3 on: April 28, 2017, 03:32:06 PM »
I have used these on my last 3 bikes
http://www.kuryakyn.com/products/3880/premium-ribbed-floorboards
they give you 5 mounting options
 The mini boards give you 3 mount options and is what I used for pillion pegs on the last 2 bikes.... but the bigger boards if they fit make good pillion boards too.
http://www.kuryakyn.com/products/4307/premium-mini-boards-with-comfort-drop-mounts
http://www.kuryakyn.com/products/4686/kinetic8482-mini-boards
I found it good to be able to easily adjust them to to pretty much any angle Smiley
oldsmokey
« Reply #4 on: April 28, 2017, 06:11:54 PM »
Excellent cooldude More options Undecided They do look good, they are on the list to search out. Thanks.
