February 13, 2026, 07:06:11 AM *
Author Topic: Air Horn fitted  (Read 1572 times)
Leathel
New Zealand
« on: April 29, 2017, 06:05:38 PM »
 Well I decided to fit the bigger horn first, fitted up OK and a cover put on the air compressor that matches my oil filter cover, I still have a second high pitch air horn to fit....if I feel like it, most likely will fit the second horn as it sounds good with the twin tone (Loud too) But it will be when I get a bit more spare time.
The video doesn't do the horn justice, sounds louder in person
powered by Aeva
(might be better on youtube?)
« Last Edit: April 29, 2017, 06:08:41 PM by Leathel » Logged
« Reply #1 on: April 29, 2017, 06:15:38 PM »
« Reply #2 on: April 29, 2017, 07:26:23 PM »
That's the second worst oil leak I ever saw.
Leathel
New Zealand
« Reply #3 on: April 29, 2017, 07:53:29 PM »
Damn the worst leek must have been a shocker...... If it looked worse than the drips of water from water blasting.... The ute was parked ready for its bath too....but that never happened Tongue
north-aurora
Batavia, IL
« Reply #4 on: April 30, 2017, 07:23:57 AM »
What kind of horn is that and where did you buy?
« Reply #5 on: April 30, 2017, 11:23:49 AM »
If what appears correct in my eyes,  what type of clamp did you use and where got since looks like it is attached to the top of the crash bar.
I want to put my howards horn on right side where the OEM stock horn is above that.
which side is preferred to mount larger horns and why?  right or left?
« Reply #6 on: April 30, 2017, 12:30:25 PM »
Wow, does that thing shoot beer at people?   Cool.  cooldude Grin
Harryc
Sebastian, Fl
« Reply #7 on: April 30, 2017, 12:49:38 PM »
Grin , Nice job Leathel, looks good.
Leathel
New Zealand
« Reply #8 on: April 30, 2017, 01:52:38 PM »
The clamp on the crash bar I made out of .8mm Stainless steel sheet steel, I mounted mine to the left as it had spare threaded hole to mount the pump, It could have gone on either, I will be mounting a second or twin set on the RH yet but not locked that in, I have a pair here that sounds good with it but they are chromed plastic and they fade apparently so rethinking that atm .... may get a shorter single and mount the other side.
Leathel
New Zealand
« Reply #9 on: April 30, 2017, 02:01:36 PM »
I got mine of Ebay..... I actually got two (one for a friend) but both compressors didn't work so am sorting that ATM (PITA) ..... I had a spare compressor here for my high pitch horn so at least I have this running.
I am told they are on Aliexpress to as another mate got one from there...$25 ish to my door
Leathel
New Zealand
« Reply #10 on: May 12, 2017, 04:47:43 PM »
I have fitted the cheap twin high pitched horns to my bike so I have the triple horn sound, Have yet to cover the pump and will keep looking for an affordable steel set like I want but cheap ones will do for now
 They are to loud to use in my workshop....my ears are still ringing Tongue
https://youtu.be/bRIvtPDOxt8
they will surely get the attention of they blind drivers starting to pull out Cheesy
Leathel
New Zealand
« Reply #11 on: May 17, 2017, 04:32:06 PM »
I put a stainless cover on the RH air horn compressor.....
Looks better than red
I was going to do another Bourbon can cover like on the LH air horn but that takes longer to fiddle with than I had time, not sure which I like better
Harryc
Sebastian, Fl
« Reply #12 on: May 17, 2017, 04:41:26 PM »
They sell Bourbon in cans over there? Wow you guys are hard core. Smiley. The stainless cover looks great.
« Reply #13 on: May 17, 2017, 04:56:38 PM »
2funny Them Kiwis are tougher than I realized.  Smiley The stainless cover does look good, but I like the Bourbon can better. More unique.  cooldude
Leathel
New Zealand
« Reply #14 on: May 18, 2017, 03:36:04 PM »
Bourbon and cola... 4-8% mix....handy at times but not like a good quality drop with ice Tongue
I have another can I emptied from the bottom so may end up the same as the other side at some stage
 Still have my new YSS Shocks &  progressive front springs to fit, Float valves are on the way so I can try and set the floats to stop the needles leaking and flooding it the bike is left Idling so any spare time goes in to that first.
Simmy74
Lapeer Mi
« Reply #15 on: May 19, 2017, 09:05:58 AM »
That thing is begging for a flame thrower mod
Guns don't kill people.   Drivers with cellphones do.
