February 13, 2026, 05:07:12 AM *
Author Topic: LED License Plate Bulb Replacement  (Read 2015 times)
cogsman
Newmarket, Ontario, Canada
« on: April 30, 2017, 09:47:47 AM »
Hi All,
Is it possible to replace the license plate light bulb with an LED, and if so, what size/type is needed for a plug and play replacement?
WintrSol
Florissant, MO
« Reply #1 on: April 30, 2017, 11:25:22 AM »
The bulb is a Stanley #67, which does have LED replacements. Unfortunately, most beam the light like a flashlight, with not much to the side.
Here are three; only the top one may work, though: https://www.superbrightleds.com/cat/led-vehicle-replacement-bulbs/filter/bulbnumber,67,197,8879:
cogsman
« Reply #2 on: April 30, 2017, 07:22:11 PM »
What would you think of something like this?
http://www.stillookin007.com/1156-BA15S-13-LED-Cool-White-1141-1156-2056-BA15S13SMDCW.htm
There is a 27-LED version but it may be too large to fit in the lens...
http://www.stillookin007.com/1156-BA15S-27-LED-Cool-White-1141-1156-2056-BA15S27SMDC-W.htm
WintrSol
Florissant, MO
« Reply #3 on: May 01, 2017, 09:25:32 AM »
The 1156 uses the same base as the 67, but the glass end is a lot larger. You could try measuring how much length the lamp will hold; I can't get to the back of mine right now, or I'd do it.
EDIT: I pulled the bike forward enough to measure - there is about 20mm for the globe, so that first one you linked might fit. It will be very close, though.
« Last Edit: May 01, 2017, 01:38:16 PM by WintrSol » Logged
buickid
'98 GL1500CT
Honolulu, HI
« Reply #4 on: May 01, 2017, 03:57:32 PM »
I ordered this, installed it, and it's plenty bright, illuminates the license plate completely.  I've ordered several times from them, and shipping is always prompt.
https://www.superbrightleds.com/moreinfo/tail-brake-turn/67-led-bulb-15-led-forward-firing-cluster-ba15s-retrofit-car/169/766/
« Last Edit: May 01, 2017, 03:59:35 PM by buickid » Logged
WintrSol
Florissant, MO
« Reply #5 on: May 01, 2017, 04:28:49 PM »
One of the diagrams for that one does show side-firing LEDs; there must be 6. I'm guessing it is bright enough that, even though 9 of the LEDs point at the back wall, there's still plenty left.
I do like dealing with them; they're about 7 miles from me, so shipping is not an issue.
