February 13, 2026, 05:07:18 AM *
Author Topic: 10" Fat mini apes fitted  (Read 1921 times)
Leathel
New Zealand
« on: May 03, 2017, 04:35:19 PM »
I finally received the bars I ordered late Feb and while they are not quite as I expected them (only had measurements and pic of similar on the site) they are comfortable, only done a real short run but I like the feel, will do some more miles and see if I want to adjust them (Roll them up)
they are not as turned in as the original bars, much higher than them too, The temp bars I had on with the long risers were more like dirt bars and what I thought I wanted but they got my wrists after a while, these don't have the same pressure points as those so time well tell if they are what I wanted.
Joss
Fallon, NV
« Reply #1 on: May 03, 2017, 06:24:58 PM »
How Do from Minnesota US!
Can you post a picture with the apes fitted. I'm thinking of changing Hbars as well. Curious about the look.
Take care..........Tom Jones
"A man's true measure is the strength of his word."
Honda Valkyrie 1500CT (Old School)
BMW K1600 GTL (New School)
Leathel
New Zealand
« Reply #2 on: May 03, 2017, 08:52:49 PM »
They are fitted in those pics, Although they could be pushed forward more so they are more upright to get more height if I need it, I just set them where I felt comfortable, They higher, not facing quite as far back. Here are some pics with the old bars wire tied in place
I will go for a longer ride when work is done and take the tools to adjust if I need too Smiley
« Reply #3 on: May 04, 2017, 05:04:01 AM »
Did you know when riding it's seems to be best to have the bars set so the the back of your hand makes a straight line into the top of your forearm.
I know that's a generalization.
Leathel
New Zealand
« Reply #4 on: May 04, 2017, 12:26:55 PM »
That is almost as they are, could roll up a touch more, But I loved the way they felt, so much easier to corner than the factory bars, counter steers naturally and even though I was riding at night I had a ball through the twisting roads for over an hour last night.....looking forward to getting out in daylight Saturday Cheesy
The bike used to want to push wide on the twisty roads that I used to counter by body position....not now. I am surprised it made as much difference as it has.
next is suspension (new fork springs and shocks coming) small screen, I don't want totally out of the wind just weight of the arms and back rest ....when I find the time Smiley
Harryc
Sebastian, Fl
« Reply #5 on: May 04, 2017, 02:38:45 PM »
Did you have to change out any cables, and of course...where did you get the bars/model/manufacturer? Smiley Are they 1" bars? I just put new risers on, so if they are more than 1" I am out. Lol
« Last Edit: May 04, 2017, 02:40:36 PM by Harryc » Logged
Leathel
New Zealand
« Reply #6 on: May 04, 2017, 03:00:21 PM »
They are 1 1/4" and I got them locally, made over here so not so economical for you, he does 1" bars as well and I thought about those as they are cheaper but I have clamps for a screen that are 1 1/4"... but the 1 1/4" 2" high risers were way dearer so I should have ditched the screen bits  Shocked
 The wires had plenty of length....the only thing that was tight was the clutch hose, brake hose not quite as tight but both are not under tension so are fine and still run like they used to be, choke and throttle cables sit better now.
I am not sure I will use this supplier again, he was real slow getting them made
36" wide, 10" rise, 9" pull back, 12" center width is the specs I asked for
I was going to ask for some Custom T bars but after trialing different risers with bars it showed it would block the lights on the headlight.....and just didn't look right
His page for reference
http://thehandlebarcompany.com/harley-davidson-handlebars.html
Harryc
Sebastian, Fl
« Reply #7 on: May 04, 2017, 03:10:37 PM »
Thanks Leathel. I am itching to try the bars I had on my Shadow 1100 on the Valk. I loved them...might try it someday.  They are basically 8 1/2 " mini apes. Very comfortable and cheap. They have half the pullback over stock and 1.5" wider (good for us bigger guys). Quality was excellent. They needed to be drilled for the Honda controls, but that was no big deal to do.  http://www.jpcycles.com/product/5000065
« Last Edit: May 04, 2017, 03:29:10 PM by Harryc » Logged
Leathel
New Zealand
« Reply #8 on: May 04, 2017, 03:42:10 PM »
They look the ticket, because I have mine angled back a little the I am not using the full rise.... but I like the extra height and width
