April 11, 2026, 05:07:32 PM *
Author Topic: Hey Don in SC  (Read 723 times)
« on: May 06, 2017, 12:58:11 PM »
I saw your ad in the Classifieds... hope you get that fine bike back in top shape... you
live in Virginia now?
Don in SC
I'll do my part
Sumter SC And Fredericksburg Va
« Reply #1 on: May 06, 2017, 05:30:25 PM »
I just took a job up here at Dahlgren Naval station. I'm in the process of going through the bike to make sure ever thing is good to go, Due to two knee replacement the bike sat a lot, and the carbs gummed up. I had them out three time to fix all the problems. The fuel rails were leaking the last time so I had to pull the carbs back out to replace them . (I can now pull the carbs in 30 minutes  Cheesy ) I have an issues with the clutch not wanting to pull in. I replaced the clutch master cylinder drain all the old fluid out an flushed the whole system with half a bottle of Dot 3 then purged the system. It moves now just not sure how its going to work when I get done, I may need to rebuild the slave cylinder.
I should be back on the road this weekend if the rain stops! Its a pain working on the bike up here  because most of my tools are still in SC.
 Good to here from you again. If you make it this way look me up.
Don
TJ
Lake Placid , Fl.
« Reply #2 on: May 07, 2017, 01:30:05 AM »
« Reply #3 on: May 07, 2017, 06:34:45 PM »
DOT 4 is recommended for it's higher boiling point.
Don in SC
I'll do my part
« Reply #4 on: May 08, 2017, 12:46:50 AM »
The saga continues...
http://www.valkyrieforum.com/bbs/index.php/topic,94751.msg941274.html#msg941274
