February 13, 2026, 07:06:06 AM *
Author Topic: No Power (part 2) - Found Solution...  (Read 1305 times)
mrgeoff
My 99 CT..."Liahona"
Augusta, GA.
« on: May 06, 2017, 01:19:24 PM »
First of all, I want to say Thanks to All those who put their minds and time to helping...Next, I want to say I failed to triple check my trouble shooting process...The wires at the top of the Starter Relay Sw. I put back together, back on the wrong terminals...The Red wire was on the proper terminal but I put the Yel/R wire next to it, instead of on the terminal in front of it(as you are looking from the front terminals)...I found it while I was checking the plug on the Side Stand Connector...Just goes to show that checking everything more then twice is a lot better than assuming because you had just checked the circuit a few hours before...!!! Just waiting for the new Starter Relay Sw. to come...I fastened the connections temporarily and went for a ride...All is well...!!! The good thing is that I have a better understanding of my girl's electric circuits...also, my Starter Sw. has been cleaned and should have many years trouble free...Thanks again ya'll...!!!
mrgeoff/SANDMAN
indybobm
Franklin, Indiana VRCC # 5258
« Reply #1 on: May 06, 2017, 02:34:58 PM »
Good to hear that it is ok. Since it started I am assuming that the starter relay is working properly.
Just so you know, the new starter relay will not come with the red connector to repair your wiring.
If you need the red connector, you can get it here:
http://www.cycleterminal.com/solenoid-connectors.html
So many roads, so little time
VRCC # 5258
mrgeoff
Augusta, GA.
« Reply #2 on: May 06, 2017, 04:20:06 PM »
Yes, I know...I already ordered the red cover too...Thanks for the input...!!!
mrgeoff/SANDMAN
