April 11, 2026, 06:44:44 PM *
Author Topic: Ham operators  (Read 674 times)
JimmyG
« on: May 10, 2017, 02:51:44 PM »
Any hams on here that do cw?  I saw a Valkyrie yesterday.
New Haven, Indiana
« Reply #1 on: May 10, 2017, 08:12:15 PM »
K9AXM here. I used to do QRP CW.  Since I'm in an apt now, I'm no longer active.  Too much hassle to hide an antenna.  Sold all my stuff.
dreamaker
Harrison Township, Michigan
« Reply #2 on: May 10, 2017, 11:10:12 PM »
I will assume you guys are ham operators, I have a question! I watch TV using an outside antenna with pre amp., I get about 51 channels all but one is digital. I get an interference that wipes out a few my channels, (They break up or freeze). I know that someone is transmitting something, I go to my only analog channel and I can see the interference showing a snowy like horizontal bar that rolls up. I get the impression it is a sort of radio, because the interference act like someone keying a mic. Is there a simple filter I can build to clean it up. Oddly it is not on all channels, may be only effects certain frequencies maybe. Also is there a way I can use some method to locate the source?
Alien
Ride Safe, Be Kind
Earth
« Reply #3 on: May 11, 2017, 04:16:11 AM »
KM6EWI
Ride Safe,
Alien
lakehunter
Chapin, SC USA
« Reply #4 on: May 11, 2017, 05:00:50 AM »
In part to answer your question, there are many sources of interference, very common ones are touch lamps and rf controlled devices in your own home. I have even found leaky traps on the local cable tv lines to cause interference. Always be sure to check for in home culprits before assuming radio operations. In the past I have found from helping my neighbors with radio interference from my own transmitters that the most likely source once identified as out of the home signals are the HF frequency radios. They operate below 30mhz and you can install a high pass filter on your antenna lead, preferably prior to your preamp. These cut off frequencies below 50mhz and will eliminate most interference caused by ham or cb operators. A good ham operator will utilize a low pass filter that cuts off anything above 50mhz and help keep neighbors happy so if you find someone close by you might suggest he use one, I find most cb guys don't have a clue about filters but if approached without getting them on the defensive they are usually open to putting one on. Most ham operators will give you a filter if you talk to them, I bought my neighbors one and problem solved. They used to be available from radio shack for about 15 bucks. Hope this helps and good luck, Lakehunter ( KQ4PW on the HF airwaves )
dreamaker
« Reply #5 on: May 11, 2017, 12:33:29 PM »
Thank You that is good info. The interference recently happens generally on Sat. or Sun from about 8am to around 8:30 pm, some times it doesn't happen. I used the AM radio trick, to find EMI and I also shut off nearly all electricity in the house to eliminate in house issues. I talked to couple of the ham guys and they denied it,and I don't doubt them. I just want to find a fix to keep peace in the family in the neighborhood, before going to the FCC for help. That is my last resort and I really don't want to go there.
« Last Edit: May 11, 2017, 12:38:41 PM by dreamaker » Logged
