July 11, 2025, 03:29:14 AM *
Author Topic: Trivia Question: Turn Signal  (Read 2597 times)
vanagon40
Greenwood, IN
« on: October 15, 2009, 09:25:37 PM »
When riding a Valkyrie, activating the right or left turn signal causes the right (or left) bulbs in both the front and rear sockets to flash.  BUT, activating the turn signal also causes something else to happen.  Anyone notice what that might be?
No.  It is not a blinker buddy that buzzes in the seat.  It is an OEM function.
« Reply #1 on: October 15, 2009, 09:49:52 PM »
It keeps blinking until manuallly turned off.
« Reply #2 on: October 15, 2009, 10:28:32 PM »
Also cancels the front amber running light when the turn filament is on.
Brad
Reno, Nevada
« Reply #3 on: October 15, 2009, 10:31:12 PM »
and causes the turn signal indicator to flash and flasher to make a clicking noise
Moonshot_1
« Reply #4 on: October 15, 2009, 10:36:49 PM »
Makes the turn signal indicator flash and if hit twice, the rear ejection seat to fire.
Mike Luken
Cherokee, Ia.
Chrome
London Ontario Canada
« Reply #5 on: October 16, 2009, 02:27:51 AM »
If you look closey at night,you will notice that the licence plate light will flicker abit. I wired some LED running lights using this as a power supply and they flicker as well.
Adrian
2001 Valkyrie I/S
1999 Valkyrie I/S
1998 Ace Tourer
1984 V45 Sabre
1976 CB 750 SuperSport
1969 CB 750 Chopper
« Reply #6 on: October 16, 2009, 02:41:32 PM »
Adrian
Adrian, that is usually due to a poor ground, and the turn signals have the poorest ground in the whole bike.
It is under the right side cover in the big bubble and GREEN in color.   The round  male/female ends do not seem to fit right.   I cut them off and replaced with the flat ones.   Been that way now about 7 years with no problem.   OH, no other lights dim when they flash now.
« Reply #7 on: October 16, 2009, 04:05:13 PM »
Hmmmmm....what is it? I don't use my signals enough to guess.  Undecided
« Reply #8 on: October 16, 2009, 04:28:26 PM »
F I G U R E S...................        lol...........
Didn't figure you would admit it however.
« Reply #9 on: October 16, 2009, 05:10:44 PM »
LOL we use alot of hand signals. Except at night of coarse.
Mike in AR
Redfield, Arkansas 72132
« Reply #10 on: October 16, 2009, 06:02:14 PM »
It activates the turn signal indicator in the headlight assembly.  coolsmiley
While I'm here, how do you use the smileys. I've tried, but can't seem to get them to show up.
« Last Edit: October 17, 2009, 07:31:08 AM by Mike in AR » Logged
Do not dwell in the past, do not dream of the future, concentrate the mind on the present moment.
Mike in AR
« Reply #11 on: October 16, 2009, 06:04:18 PM »
Well what do ya know. Don't know what I did, but there is the cool dudeI was trying to use. 2funny
bogator
IN GOD WE TRUST------KK4KSN-------
Valley,Al
« Reply #12 on: October 17, 2009, 01:54:12 AM »
MIKE, we exspect that from Arkansas,                 LOL        LOL
mikeb
vrcc-29271
dansville mi by lansing mi
« Reply #13 on: October 17, 2009, 04:25:36 AM »
if both bulbs on the front are on at the same time the indicator in the headlight would not light ..
the little green light is feeding off the pos sides of both bulbs in the front it draws so little current it uses
the non lit side as a ground and if the filament support post every shorts out both sides will flash .. yes i have seen this happen more than once . so if both sides are blinking at the same time no indicator..
i dont care what you ride just ride
mike & kari
mivrcc capital city leader
s.s.d.d.
Mike in AR
« Reply #14 on: October 17, 2009, 07:29:21 AM »
I'm not sure, but I think he meant  when both lights, left front and rear,or right front and rear, not both, front or rear, at the same time. Of course, I have been known to be wrong occasionally. javascript:void(0);
« Reply #15 on: October 17, 2009, 09:56:31 AM »
I don't know about everyone else's bike, but in my case, when the turn signals are activated it usually means that the rider is deactivated and forgets to turn 'em off.
Printer Mike
Eatonton, Georgia
« Reply #16 on: October 17, 2009, 12:44:34 PM »
The bike has a tendency to lean in the direction the turn signal indicates... crazy2
Never give up!
Momz
ABATE, AMA, & MRF rep.
« Reply #17 on: October 17, 2009, 03:12:10 PM »
The "indicator" lamp on the headlight flashes in sequence to the turn signals. DUH!
ALWAYS QUESTION AUTHORITY!
Printer Mike
Eatonton, Georgia
« Reply #18 on: October 18, 2009, 07:42:09 PM »
Something to do with the lean angle switch? Disable it while the turn signal is on would sound logical.
Never give up!
vanagon40
Greenwood, IN
« Reply #19 on: October 19, 2009, 07:17:50 AM »
Sandy in the third post had what I was looking for.
Turning on the right turn signal turns OFF off the right front (amber) running light.  And turning on the left turn signal turns OFF the left front running light.
I did forget that it also illuminates the blinker signal on the headlight (standard/tourer) and where ever on the interstate.
I was interested in this as I plan to change my rear turn signals to three function lights: running lights, brake lights, and turn signals.  Seems like it would be a good idea to turn off the rear running light also when the signal is blinking to highlight the blinking.
Printer Mike
Eatonton, Georgia
« Reply #20 on: October 19, 2009, 08:49:31 AM »
Sandy in the third post had what I was looking for...
I assumed that wasn't it because the "Right Answer" bell didn't go off... Cheesy
Never give up!
vanagon40
Greenwood, IN
« Reply #21 on: October 19, 2009, 09:03:35 AM »
Yeah, my fault.  I was out of town all day Friday, and then I do not get to the computer much on weekends.  I should know better than to make that type of a post on a Friday.
Printer Mike
Eatonton, Georgia
« Reply #22 on: October 19, 2009, 08:02:24 PM »
It's all good. cooldude I needed the brain exercise anyway! I was really reaching....LOL
Never give up!
