February 13, 2026, 07:06:13 AM *
Author Topic: Cyclops LED bulb adapter  (Read 1845 times)
Ken Tarver
North Mississippi
« on: May 14, 2017, 04:48:27 PM »
Cyclops LED bulb in a tourer or standard.
Did anyone use the 1/8" adapter that came with the bulb?
Make any difference, good or bad?
Ken
« Reply #1 on: May 14, 2017, 05:38:51 PM »
Yep.  Used it.  Didn't help.  Tried w/o it.  Also no help.  Inverted the mount flange.  No joy.  I could not find a position that would focus that bulb.  Or three other designs similar. The problem is, the reflector is made for a tungsten filiment in a specific size and position.
But the good news is - there are are at least 2 companies making an H4 LED that emulates a halogen H4 bulb pretty closely.  I just got a pair of them in because I knew why the Cyclops and other LED H4's won't focus - I was waiting for someone to make exactly what they did.  Installed it - almost as bright downrange as my 130/90 halogen, but with much whiter light at 6500° Kelvin.  Really pleased, put them in Jade and George.
This is the one I bought:  https://www.genssiled.com/index.php/product/elite-led-headlight-conversion-kit-6000k-bulbs-8000lm/
Watch this video - explains and demonstrates it well:  https://www.youtube.com/watch?v=O8TVgPqy4u0&t=52s
This one looks to be identical, by Phillips, and at ebay for $30 less:  http://www.ebay.com/itm/Pair-160W-16000LM-LED-Headlight-Bulbs-Philips-H4-9003-Plug-Bulb-White-6000K-Hi-L-/142096084883?hash=item2115962f93:g:tzoAAOSwV0RXvWtI&vxp=mtr
« Reply #2 on: May 14, 2017, 07:29:19 PM »
The way they rate wattage is confusing to me. One of the advantages to me is the reduced amps of LED's. But are they saying each bulb uses 80 watts ? Or are they comparing the light output to a 80 watt halogen bulb ?
WintrSol
Florissant, MO
« Reply #3 on: May 14, 2017, 08:43:49 PM »
I'd like to see an actual current measurement. The page says 'up to 8000 lumens' and '160LM/W', which means 50W, not 80W. If 80W, then they would be 100LM/W. At 50W the current would be close to 4A, while 80W would be a little over 6A.
« Reply #4 on: May 15, 2017, 06:35:00 AM »
It's not clear to me either.  Also not consistent between companies.  I note they talk about all the lumens a bulb could deliver if all the emitters where on at once - but they aren't all on at once. Also it's not clear what is in the regulator module. I note the heat sink on the inside end of the bulb does get warm to the touch.  I didn't check it after it was run for some time to see how warm it gets, but only had my hands on it while I was aligning the bulb to focus it. The warmth implies watts getting used.  I did not put the light on a meter to measure power draw.  I wasn't real concerned with that at the time because both bikes I put it on have my high-power headlight relay mod which can deliver much more power than an LED bulb could possibly use.
« Last Edit: May 15, 2017, 06:52:43 AM by MarkT » Logged
WintrSol
Florissant, MO
« Reply #5 on: May 15, 2017, 10:40:29 AM »
The regulator module is a constant-current source, so the LED elements don't get more or less current when the battery Voltage changes; note also that it will work on 24V systems.
« Reply #6 on: May 16, 2017, 03:42:58 PM »
on my search for the best LED headlight technology.
Yep, I think those $39 buckers I found on eBad
may be the ticket for Interstates as well.
I say this with some hesitation as the last inferior LED bulbs I tried on my IS had inside the bucket fans.  Easy install, but they burned too hot and started spiderwebbing my reflectors.  Went back to the best halogens I could find, Philips +130 H4.  They are a good bulb, but only burn up to 450 hours.  Pulled the trigger on the above bulbs, received today.  With a little cussing over placement of the voltage regulators, I got both of the new Lumiled bulbs in, even using the OEM dust covers -- the cooling fins unscrew so you can install them outside the dust covers, exposed to fresh air.  Hopefully that will be enough to keep the bucket cool.  I really like these bulbs.  They're adjustable, they don't require a fan and they are hellishly bright.  I'm still seeing spots!   Shocked
« Last Edit: May 16, 2017, 03:53:49 PM by Valkorado » Logged
« Reply #7 on: May 16, 2017, 06:22:47 PM »
I tried those and was getting a dead spot in the center. Went with a LED that has lights on 3 sides, kinda a triangle. Much better lighting and no dead spots. On bright they light up signs 1/2 a mile away. Even during the day in noon sun the light up stop signs.
« Reply #8 on: May 16, 2017, 07:11:01 PM »
Nope, no noticeable "dead spots" with these bulbs.  That's their main selling point, they replicate the halogen pattern almost to a tee.  Plus they are angle adjustable.  Yours may differ, but many "360 degree" LEDs bleed light, often into the eyes of oncoming traffic.  Check the YouTube video in MarkTs post above.
« Reply #9 on: May 17, 2017, 04:35:51 AM »
That was just my experience with them, they may work very well for you. Just didn't suit me.
