April 11, 2026, 01:18:01 PM *
Author Topic: Center Carb left bank  (Read 684 times)
SpidyJ
Murrells Inlet
« on: May 17, 2017, 12:20:18 AM »
...must have a leaky needle seat.  Had hydrolock after work yesterday.  Good thing I am in the habit of always bumping the starter a little first.
removed plug and it was wet....bumped the starter and she squirted then started  and ran with the plug out.
A disaster averted.....Big Bill F please come to SC , It's time for a carb overhaul !
1999 Fast Black Interstate
Peace,
johnnywebb
Misfit
Colorado Springs Colorado
« Reply #1 on: May 17, 2017, 01:21:33 PM »
You don't need a carb overhaul. You need to fix your petcock or add a electric fuel shut off and clean or replace the needle valve and clean the seat on the offending cylinder.  cooldude
SpidyJ
Murrells Inlet
« Reply #2 on: May 19, 2017, 08:17:47 PM »
I have the Dan Marc so I guess it is just what's in the bowl due to a dirty needle seat......I wanted a rebuild because the bike is 18 years old and leaks sometimes between the carbs. Annoying and maybe a bit dangerous.
Peace,
johnnywebb
Leathel
New Zealand
« Reply #3 on: May 20, 2017, 05:08:38 AM »
how close to the T is the dan marc? There is a fair amount of fuel in the rails and pipes so I put mine right on the T
 I have a set of float valves on the way as all 3 carbs on the left side are leaking a bit, number 4 quite badly but never had enough to stop starting....
runs very rich and splutters until it clears though, I have also been tapping the starter just in case as well, parts should be here this week for me.
O rings are pretty easy to replace on the fuel rails Smiley
« Reply #4 on: May 20, 2017, 10:33:54 PM »
Have you tried running some fuel thru the carburetor to try and flush out the line and bowl ?  I find that works most of the time. But, keep on just tapping that little right hand button.  cooldude
