April 30, 2026, 01:59:13 PM *
Author Topic: 2014 valkrie 1800  (Read 5187 times)
Rdaugherty
« on: May 22, 2017, 07:17:30 AM »
Bought brand new 2014 valk 1800  only has 400 miles on it now I got a valve like tick sound in left front anyone have any ideas? It comes and goes sometimes when it happens it gets loud sometimes it don't tick at all . Help!
« Reply #1 on: May 22, 2017, 08:33:00 AM »
Hard to say if you're hearing what I'm hearing, but I just ignore it
and expect that the motor will run forever...
dinosnake
« Reply #2 on: May 22, 2017, 01:03:46 PM »
Oil.  Either wrong weight or wrong fill level.
Do an oil and filter change and make sure both are correct.  That should cure your issue, if not then have the dealer check it out.
hungryeye
Scottsdale AZ & Climax NC, formally freehold, nj
« Reply #3 on: May 22, 2017, 02:20:28 PM »
Check oil, if all good it prolly needs a little running in. You should have warranty left, 3 years from original purchase date, transfers to any owner.
2014 F6c Red ish
1983 GL650 cream puff
2010 Spyder RS
we DRIVE our cars, we RIDE our motorcycles!
goldstar903
« Reply #4 on: May 22, 2017, 03:34:21 PM »
The Valkyrie has shims under buckets. Normal, from time to time.
I love to go fast, but my wallet doesn't! Maybe I should leave my wallet home!
Stealth power
« Reply #5 on: May 26, 2017, 09:04:30 AM »
It is normal on all of the GL1800 engines. This has been discussed at length on the F6B board. The ticking you hear are the injectors and it is perfectly normal but it seems to be louder on some than others.
« Reply #6 on: May 26, 2017, 03:31:34 PM »
cooldude cooldude
I agree, it happened with mine and I decided to let some time pass without doing something with it and it has gone away. Most of the times it was just after I started it sometimes at the end of a run. Not loud but noticeable.
I remember this even happening with the 1500 some guys reported.
« Last Edit: May 27, 2017, 06:32:47 AM by Robert » Logged
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #7 on: December 12, 2020, 07:41:18 AM »
Old thread, but to those newer Valkyrie owners...
I have the same valve tick sound. Most noticeable on cold start, obviously as oil has not circulated to where it needs to be. Same symptoms, sometimes very loud, sometimes barely noticeable. Sometimes can't here it at all. After warmed up, blip the throttle and it goes away. Maybe I just need to blip my throttle more Smiley
