April 11, 2026, 01:17:25 PM *
Author Topic: Air Pressure Dark Side  (Read 679 times)
NW roller
Dunkirk MD
« on: May 24, 2017, 12:33:51 PM »
Hello all. Iwas was just wondering what air pressure you run in your Darkside rear tires. I recently had a Austone Taxi tire mounted on My Interstate.  the guy that mounted it has it aired up to 40 psi. i know a lot depends on weight and such. I'm not a little guy 6'3 265lbs any help would be appreciated. All those that know me know what i do for a living. My fellow Motor cops think i'm nuts but i was tired of buying tires every summer.
Those who won't listen must feel.   David B
Cliff
Manchester, NH
« Reply #1 on: May 24, 2017, 12:41:52 PM »
I'm 6'5" 290lbs run my General tire Altimax HP at 40 PSI.
VRCC # 29680
« Reply #2 on: May 24, 2017, 12:42:06 PM »
i run 34 in mine but i don't have the taxi tire. I have a Yokohama Avid Envigor. I started at 40 PSI for a couple rides then let out little by little until it felt right.  cooldude It now feels right at 34PSI
Gryphon
Resistance is futile; if less than 1 ohm.
Fulton, MO
« Reply #3 on: May 24, 2017, 01:31:46 PM »
I run my Altimax HP at 36, but I'm only 5'11" and 240#.  When I get the champiro mounted I'll probably start at about the same and adjust from there.
« Reply #4 on: May 24, 2017, 01:35:43 PM »
I've never used an Austone.
42 will wear the center on a Cooper
40 will wear the center on a Goodyear
38 will wear the center on a Champiro.
michaelyoung254
Huntsville, Texas
« Reply #5 on: May 24, 2017, 01:57:05 PM »
I have the Yokohama Avid Envigor, and I run it between 30 & 32 psi. My first darkside tire was a Falken which I ran at about 40 psi. It felt a little hard, and the middle of the tire became worn down pretty quickly (Too fast for a darkside tire).
The Yokohama at 32 psi feels good, and seems to be wearing a lot better.
1998 Standard - Pearl Sedona Red & Ivory Cream
JC19
Rush City, Minnesota
« Reply #6 on: May 24, 2017, 02:24:00 PM »
I have the Yokohama and experimented all up and down the scale. Landed at 40psi.
« Reply #7 on: May 24, 2017, 02:24:09 PM »
6' 2" bout 230-235 and I run my A T T 36 37 P S I with good results for Me-emphasize ME! And I can/have leaned it over til hard parts start makin noise. And have walked er to triple digits plus and felt/feel comfortable. The ONLY M/C specific tire I have ever been worried bout-O K-scared the crap outa me in a rain storm after the oil washed of the surface and felt like it wuz STILL oily was a dunflop e-3. Couple folks here have had or have heard of bad things with the A T T-I ain't one of them. RIDE SAFE.
« Reply #8 on: May 24, 2017, 02:28:32 PM »
Monitor center wear.  cooldude
« Reply #9 on: May 24, 2017, 02:43:46 PM »
I run 40.  It does wear the center more than the outside tread but I prefer the solid feel.  Any less that 40 lets her wobble a bit at speed in a curve.
« Reply #10 on: May 24, 2017, 05:01:00 PM »
On my Goodyear Assurance Triple Tred 205 60, 40psi throughout it's life (on my interstate) of 37 thousand miles saw it wear evenly across the tire.  I have two other GATTs on both bikes at constant 40, and also have even wear.  And I check them routinely too.
Just sayin'
I can go down to about 38 with no symptoms, but much below that (just a few times) and I have had the wallow effect too.  Somehow it got down to about 30 once, and it slightly rubbed my swingarm too.  No damage, and caught right away.
« Last Edit: May 24, 2017, 05:03:38 PM by Jess from VA » Logged
