February 13, 2026, 08:31:15 AM
Fuel selector is backwards/reversed
Topic: Fuel selector is backwards/reversed (Read 1024 times)
spartacus1215
June 03, 2017, 10:04:31 AM »
Hello folks, moron here...I had a fuel issue so I pulled my tank, removed the petcock and put it all back together after cleaning and now the selector is backwards. What did I do wrong? Thx--Bob
98 Standard
Re: Fuel selector is backwards/reversed
June 03, 2017, 10:15:03 AM »
I haven't taken mine off lately, so...
I think that before you tighten it, you can point it in any direction, then
hold it the way it is supposed to be and tighten it all the way.
spartacus1215
June 03, 2017, 10:54:25 AM »
Firefighter
Harlingen, Texas
June 03, 2017, 07:49:04 PM »
Do you mean the petcock is turned around the wrong way? Like Hubcapsc says you loosen it and turn it straight. If you mean the selector knob is out of sync you loosen the phillips screw and pull the knob out and figure out how to position it back so off is off, etc.
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
June 04, 2017, 10:22:34 AM »
The post the knob screws on to on the petcock isn't square, one corner is rounded off. The knob should match the shape so mount/install accordingly.
Firefighter
Harlingen, Texas
June 04, 2017, 06:06:35 PM »
Every time I get to thinkin I know everything, I learn something!
1978 Honda 750
