February 13, 2026, 08:32:02 AM *
Author Topic: OEM Front Rotors for 99 Interstate  (Read 1183 times)
Karen
Boston MA
« on: June 04, 2017, 03:08:46 PM »
I've been looking all over for Honda rotors, but don't see any anywhere! Is there a Honda substitute available that anyone knows of? Thanks for any info!
« Reply #1 on: June 04, 2017, 03:20:23 PM »
New ones are about $170 each...
http://www.partzilla.com/parts/search/Honda/Motorcycle/1999/GL1500CF+A/FRONT+WHEEL/parts.html
You can get used ones on eBay, I got a used rear from a low mileage bike from Pinwall for cheap, I think it
is perfect. Here's a front set, I don't know this seller, there's more if you look:
http://www.ebay.com/itm/99-Honda-GL1500-GL-1500-C-Valkyrie-front-brake-rotors-disks-/311497534163?hash=item4886b32ad3:g:JLgAAOSwwE5WXuHw&vxp=mtr
Google "ebc front rotor valkyrie" people like those, they seem expensive...
« Reply #2 on: June 04, 2017, 06:50:58 PM »
GL1800 rotors
http://www.valkyrieforum.com/bbs/index.php/topic,2838.0.html
I thought the GL1500 also works. I know the rears work, I have a GW rotor.
« Reply #3 on: June 04, 2017, 09:23:38 PM »
+1 on the 1800 wing rotors. I put them on my old Valk. Worked great.
Karen
Boston MA
« Reply #4 on: June 05, 2017, 06:55:25 AM »
thank you all very much; I went with PartZilla. Will get the Gold Wings next time, if needed. See you at InZane with brakes that will pass inspection!  Kiss
Bagger John - #3785
« Reply #5 on: June 05, 2017, 06:58:48 AM »
Ehhh...do what the Harley chopper crowd does and run a naked front spool.
Stopping quickly is SOOOOO overrated...  Cheesy
« Reply #6 on: June 05, 2017, 12:16:47 PM »
for next time or anybody else who wants to know
CBR600F F4 (not FI model) ,98-08 VFR800 and 92-93 CBR900RR all front rotors will bolt on.
oem thk is 4.4-4.6mm,  min 3.5 mm.   CBR and VFR are lighter rotors, newer design. VFR weighs more than the CBR900
The Valkyrie had a new thk of 5.0mm which is more than any other OEM Honda rotor of the ones that fit. min 4.0mm
most aftermarket are less thk new than valkyrie OEM. thicker front pads with the thinner rotors should be considered.
