February 13, 2026, 08:32:41 AM *
Author Topic: Radiator Fan Motor  (Read 963 times)
dancnman
Houston, Texas
« on: June 06, 2017, 11:24:51 AM »
My 99 Interstate needs a fan motor. Other Valkyrie's have a different part number. What is the difference?
Reality is that thing which does not change simply because I choose to ignore it.
« Reply #1 on: June 06, 2017, 01:22:18 PM »
The Interstate has a different radiator shroud which probably means the fan mounts a little bit differently. This is because of the '"pods", specific to the Interstate.
dancnman
Houston, Texas
« Reply #2 on: June 06, 2017, 07:36:45 PM »
Ah. Thanks. I wonder if the motor would mount in the shroud.
Thanks.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #3 on: June 07, 2017, 06:31:52 AM »
I guess you have done all of the checks:
1. Make sure the fuse is good.
2. Ground the wire at the thermostatic switch at the lower left side of the radiator with the key on.
3. Disconnect the wire to the thermostatic switch and check for 12VDC between it and a good ground  with with a volt meter with the key on. With the ground side of the motor disconnected from the thermostatic switch you should have 12VDC there until that line is grounded.
So many roads, so little time
VRCC # 5258
