February 13, 2026, 10:25:05 AM *
Author Topic: Kuryakyn LED Battery Gauge  (Read 1596 times)
Gideon
Indianapolis, IN.
« on: June 07, 2017, 01:02:36 PM »
Has anyone come up with a unique way to mount a Kuryakyn LED Volt Battery Gauge?
Photos please  Smiley
Bagger John - #3785
« Reply #1 on: June 07, 2017, 02:12:33 PM »
Got one on my Tourer's handlebar using a custom Cushman scooter mount which was machined specifically for it.
When I change the gauges around this summer or next it'll go up for sale.
Will post pics when I get a couple.
RainMaker
Arlington, TX
« Reply #2 on: June 07, 2017, 02:16:14 PM »
Which model Valkyrie are you mounting it on?   More mounting spots on an I/S.
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
Gideon
Indianapolis, IN.
« Reply #3 on: June 07, 2017, 02:45:54 PM »
I am sorry. I have a 2003 "Fast Black".
Bagger John - #3785
« Reply #4 on: June 08, 2017, 06:54:30 AM »
Switch to a split handlebar clamp (the one from a Shadow works fine) and you can mount a gauge between the risers.
Gideon
Indianapolis, IN.
« Reply #5 on: June 15, 2017, 05:06:24 AM »
Thank you to those that replied.
God bless and Ride safe,
Gideon
« Reply #6 on: June 15, 2017, 07:21:24 AM »
I don't know if it's unique, but here's where I put mine:
Gideon
Indianapolis, IN.
« Reply #7 on: June 16, 2017, 05:45:56 AM »
Thank you!
It's unique and looks great.  cooldude
« Reply #8 on: June 17, 2017, 04:57:39 PM »
Mine has been in the right pod for years, only the face plate fell off years ago  Actually the button for the fog lites fell off the left pod the same time  We have BIG potholes here in the northeast    coolsmiley Kury wont sell the face plate so I just run it as is with the one green light on except when I turn off the bike it goes straight to yellow
I am also informed by more than a few members that that Kury gauge is not accurate possibly because it is on the fog lite circuit and not just hooked to the battery?
The $2. led's are supposedly better.
http://www.ebay.com/itm/Mini-DC-0-1-30V-Red-LED-3-Digital-Display-Voltage-Voltmeter-Panel-for-Motorcycle/131000844123?rt=nc&_soffid=5017647306&_soffType=OrderSubTotalOffer&_trksid=p5731.m3795
http://www.ebay.com/itm/Mini-DC-0-1-30V-LED-Panel-Voltage-Meter-3-Digital-Display-Voltmeter-Motorcycle-/130978113571
« Last Edit: June 17, 2017, 05:02:41 PM by Oss » Logged
« Reply #9 on: June 17, 2017, 05:20:17 PM »
Wherever you put it, you want it in a good line of sight while riding.
It's really nothing more than an idiot light to let you know if you have a charging (alternator) failure.
Idiot lights don't show green like the Kury when properly charging (and don't be surprised if you never get more than one or two green bars, ever; that's normal), but if it turns red all the time (when an idiot light should come on), you want to notice it right away and take action.
If is is put somewhere not in line of sight, you may very well coast to a stop before ever seeing red.
I have them on both my interstates mounted on the fairing, just inside the speaker panel on the right.  Up in my line of sight.  If you don't mind the wire, it could be stuck on the std/tourer inside windshield hardware (with a little male/female velcro tape).  It could probably be put on the same way on the inside of a handlebar master cylinder.
There may be one proviso:  I don't ride at night much.  The Kury LED gauge is brighter than other ordinary Valk instrument lights.  It could be a distraction at night, depending on location.
It is said a Valk idling much below 1K (idle is supposed to be 900) is not charging.  Until my bikes warm up, and after the choke is cut off, my bikes idle low, and I get a red LED on my gauge every time.  I like that this tells me it is working.  (If I set the idle up cold, the bike idles too high warm)  It's not red for long.
« Last Edit: June 17, 2017, 06:57:00 PM by Jess from VA » Logged
« Reply #10 on: June 19, 2017, 07:57:41 AM »
One or two green lights is normal when riding or idling without additional loads.  Two yellow is normal when idling with extra loads, such as turn signal or auxiliary lights on.  I may have had it go down to one yellow when idling with heated clothing turned on.  I usually turn off my jacket liner as I slow for a red light.
The lights auto-dim in low lighting conditions.  Their brightness is only a distraction when you ride from shade to sunlight and they get brighter all of a sudden.
« Reply #11 on: June 19, 2017, 09:23:40 AM »
Griff, you're right, mine goes yellow (not red) when idling low at startup.  Just looked it over again yesterday on a ride.
I forgot there was yellow, as well as green and red.
