February 13, 2026, 10:25:06 AM *
Author Topic: Whistle while you idle...  (Read 3751 times)
« on: June 10, 2017, 03:34:37 PM »
I'm NOT very mechanical, so kinda worried (And please don't laugh at me TOO much)... My Valk has recently started whistling at idle. (Whistle while you DON'T work) If I give it a bit of throttle it stops rather abruptly at around 1200 RPM, but starts back up once the RPM go back down.
The pitch climbs as the RPMs climb up until it goes silent.
It ONLY happens once the engine is good and warmed up. From cold to a good 10 minutes of riding or so and it doesn't whistle at all, I have to ride it longer than that for this to start happening.
Initially I was told doing a desmog would likely remedy it, so I did that (Which wasn't pretty for a non-wrench turner like me to accomplish, but I'm rather proud of the fact that I got it done.)
No regrets on the desmog, glad I did it, the backfiring on deceleration had gotten pretty bad on my Valk, so that was a job that needed doing, but...
The whistling is still there...
It kind of sounds like a tea-kettle that's about ready.
I've already talked to a few folks that think it's a vacuum line and needs to be replaced, not super critical though, but wanted some confirmation, I'm worried I'm mis-diagnosing it and it's a bearing going out or something that could leave me and my daughter on the side of the road somewhere on our way to Montana, so I took some video to let the experts hear, let me know what ya'll think:
Thanks for any insight!
https://www.youtube.com/watch?v=CVsrbtIrONA
« Reply #1 on: June 10, 2017, 04:10:24 PM »
Vacuum line cracked was my first thought. Since you are  desmogged, I would imagine you still have a vacuum line to the petcock. If that line is cracked you should experience fuel starvation symptoms soon.
« Reply #2 on: June 10, 2017, 04:12:54 PM »
I have no clue with this. But my first question is, is it speed related or RPM of the engine? So it's doing this while parked and just revving the engine.
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #3 on: June 10, 2017, 04:30:51 PM »
How about the vacuum Caps on the back of the intake tubes?  Did those get replaced on the demsmog?
Will also wait on reply to Chris's question whether stopped and idle or if this is moving whistle.
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
« Reply #4 on: June 10, 2017, 05:36:52 PM »
You don't say the mileage but it could be one of the cam belt tensioners. Those bearings run pretty dry and can be noisy.
« Reply #5 on: June 10, 2017, 06:11:22 PM »
That would be my guess also.
« Reply #6 on: June 10, 2017, 08:15:33 PM »
Thanks for the feedback...
It's a '98, I'm the original owner, 117,000 miles, and it happens with the bike parked in neutral...
I replaced the timing belts at 83,000 miles, if that enters into the equation?
« Reply #7 on: June 10, 2017, 09:07:26 PM »
OK on the belts but the idler pullies are still old.
« Reply #8 on: June 10, 2017, 09:22:09 PM »
So... Warm it up, take the timing belt cover off and see if that's where the noise is originating from, and then take it from there?
« Reply #9 on: June 10, 2017, 10:49:53 PM »
The pullies can be replaced.  Big Bill rebuilt mine.
You might be able to hear/locate/isolate the whistle with a piece of hose to the timing cover, without pulling it.
Not exactly sure which parts.  13's and something else?
http://www.procaliber.com/oemparts/a/hon/506cb5fff870023420a416de/front-cover-timing-belt
« Last Edit: June 10, 2017, 10:51:56 PM by Jess from VA » Logged
« Reply #10 on: June 11, 2017, 10:06:05 AM »
Okay, update and planned course of action up for discussion:
Got a automotive stethoscope, rode to warm the engine up and start the sound, and probed around, couldn't pin down where it was coming from.
One other observation, the sound is VERY temperature dependent. Sitting at idle in my garage, when the radiator fan kicks on the sound stops shortly after, and re-starts a minute or so after the radiator fan stops.
Took the timing belt cover off and couldn't notice a discernible difference in the sound, but I don't have the best hearing, had my wife check, she thinks it might be coming from that area, but again couldn't tell a difference with the timing belt cover on or off.
Checked my records, and while I did indeed change the timing belts at 80k, that was in 2007, so guess those are due anyway, and if I'm doing that and they're a failure item I'll replace the tensioner pulleys as well.
Will also order a petcock vacuum hose and see if I can replace that while I'm in there. Probably do the spark plugs as well, seeing as I don't think I've done that in 12+ years.
And once I've done all that, if it's still whistling, I'll be offering adult beverages of choice in Billings to whoever can figure it out.
« Reply #11 on: June 11, 2017, 10:49:35 AM »
Just for confirmation, when we're talking about the tensioner pulleys, we're talking about these, right?
(Honda part# 14510-MG9-008 )
« Reply #12 on: June 11, 2017, 11:02:27 AM »
That's correct. Try resetting the tension according to the service manual. Feel for smoothness when you have them loose.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #13 on: June 11, 2017, 11:32:09 AM »
Since you did a desmog, you had the intake tubes off. Could you have displaced one of the intake tube o-rings when you put it back in?
« Last Edit: June 11, 2017, 11:34:34 AM by indybobm » Logged
So many roads, so little time
VRCC # 5258
Beardo
Regina, Saskatchewan Canada
« Reply #14 on: June 11, 2017, 11:54:17 AM »
Only thing I can think of that could squeal and possibly be related to rpms and temperature is a bearing in the water pump??  Just grasping at straws.
« Reply #15 on: June 11, 2017, 02:25:06 PM »
Oh! I love tests, and tests with a reward are even better.
indybobm
« Reply #16 on: June 11, 2017, 02:48:35 PM »
I would pull the intake tubes one at a time and check for proper positioning of the o-rings. A displaced o-ring would be a big air leak.
VRCC # 5258
« Reply #17 on: June 11, 2017, 03:40:55 PM »
Are those the udder looking things that come down off the airbox? If so, it's definitely possible, but the whistling was there before I did the dessmog, and still there after...
Not an impossibility to have one that's leaking in the same way before and after being removed and put back on, but odds lower, right?
indybobm
« Reply #18 on: June 11, 2017, 05:27:56 PM »
No, the chrome intake tubes.
VRCC # 5258
« Reply #19 on: June 11, 2017, 06:02:22 PM »
The chrome intake tubes should have "tobacco stains" around their base if
they are leaking...
Firefighter
Harlingen, Texas
« Reply #20 on: June 11, 2017, 07:20:00 PM »
If the sound changes with the fan running, I would give a good listen to the alternator, take the cover off and listen there. Only other thing is could it be a vibration or buzzing noise.
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
« Reply #21 on: June 14, 2017, 07:39:57 PM »
You coming to Inzane? If so I'm about 99% sure I owe you a beverage.
Update on the story (And I still regret nothing I've done, it all needed doing anyway)
Today I replaced the timing belts, both idle tensioners, the petcock vacuum tube (And the spark plugs because hey why not).
Went for a test ride to a friend's house, got there and it's whistling.
Remembered your comment about the water pump, my friend has an automotive stethoscope, he prodded a bit, and when he hit the water pump he recoiled in pain.
Almost positive that's the culprit.
So now I'm off to order a new water pump. Researching what all is involved in changing that out. I'll google on it  and read the manual too, but anything else I need other than just the pump? Any tips or tricks beyond what's in the manual for changing a water pump?
Thanks again ya'll!
« Reply #22 on: June 14, 2017, 09:56:50 PM »
Drain your oil before pulling the water pump. The manual doesn't mention this.
Beardo
« Reply #23 on: June 15, 2017, 05:05:51 AM »
Yeah, I'll be at Inzane, won't be there til late Monday.
I'll be the guy on the black Valkyrie.
« Reply #24 on: June 15, 2017, 05:08:27 AM »
I believe you and will do so but curious, why is this necessary?
Edit - Ah, was told that removing the water pump WILL drain the oil for me, so best to do it in a controlled manner beforehand... Thanks again for the advice!
« Last Edit: June 15, 2017, 09:11:32 AM by Serk » Logged
Jeff K
« Reply #25 on: June 15, 2017, 10:01:45 AM »
And you can get coolant into the oil when you pull the pump. Best to drain it first
« Reply #26 on: June 19, 2017, 06:37:45 AM »
Question due to my impatience, I'll be able to answer this tonight myself when my new water pump is delivered but, I went ahead and pulled the old water pump last night; should the impeller turn freely once removed from the bike? I AM able to turn it but it's very stiff and requires quite a bit of effort, seems like something like that should spin freely?
« Reply #27 on: June 19, 2017, 06:43:34 AM »
Just checked my new one (never installed) and its a tight turn.  I mean it turns freely but its not like spinning a top.  it takes a bit of effort to turn it
« Reply #28 on: June 19, 2017, 08:05:05 AM »
Thanks for checking, that sounds about like the old one on mine is doing... Guess we'll see if that was the problem after I get my replacement in and get everything put back together...
Thanks again!
(I'll post an update once I know something either way just for posterity if nothing else.)
« Reply #29 on: June 19, 2017, 03:33:47 PM »
New pump came, got it put on, hoses re-connected, fluids refilled (Made the there was an o-ring on the shaft of the new pump), bled the coolant, let 'er run a bit to warm up, and it started rhythmically squirting coolant out in the space between the pump and the engine...
I'm off to google up what I can learn, but in the meantime... Anything obvious or simple before I drain all the fluids out, take the pump off, and fiddle with it some more?
« Reply #30 on: June 19, 2017, 03:44:49 PM »
Hopefully nevermind, I'm an idiot...
The hoseclamp to the top hose had stripped out and wouldn't get good and tight, I put my finger up there and it's weeping from that hose. Off to buy new hose clamps and hope that was it...
« Reply #31 on: June 19, 2017, 03:47:29 PM »
I don't know, but don't let ChrisJ CMA see that pic of the bottom of your engine.  Wink
« Reply #32 on: June 19, 2017, 03:49:57 PM »
The top of my engine isn't much cleaner... I'm challenging The Two Dans for the title of dirtiest Valk...  Wink
Beardo
« Reply #33 on: June 19, 2017, 03:55:49 PM »
Good luck, hope that was it. Not just for your sake, but because that would mean I was right. I love being right. That one other time I was right about something was glorious.
« Reply #34 on: June 19, 2017, 04:44:01 PM »
2funny
« Reply #35 on: June 19, 2017, 04:45:55 PM »
Sadly, your competition is down to One Dan. Dirty Dan has had to give up riding.
« Reply #36 on: June 19, 2017, 05:04:54 PM »
You like bourbon? I'm planning on bringing some of my home blend/aged bourbon, and it appears I owe ya' a wee dram!
Woot!
Put a new hose clamp on the top, tightened it down, started the engine, no leaks (*KNOCKING FURIOUSLY ON WOOD*). Took her for a ride, beat her hard got her hot enough for the fan to come on a few times, and no whistling! Looks like water pump was the correct answer!
Yeah, sadly had seen that, but the amount of dirt on his Valk was legendary, thus I still hold his status in high esteem and a pinnacle I can only hope to some day match... Wink
« Reply #37 on: June 19, 2017, 05:12:04 PM »
Woot!
It was pretty legendary. The pics I've seen of your bike you wouldn't stand a chance against him.  Smiley
So, it must have been a bearing in the water pump going out ? If so, good on you for noticing it before you and daughter were stranded.  cooldude
Beardo
« Reply #38 on: June 19, 2017, 05:29:00 PM »
Woot!
I'll gladly partake in a drink with ya.  cooldude
You did all the troubleshooting though, good work. Your bike was talkin to ya and you listened to her, sometimes you just need an outside opinion to put the pieces together.  Noticing the relation to the temp was  cooldude
