February 13, 2026, 09:02:09 AM *
Author Topic: New water pump leaking  (Read 1109 times)
ValkyrieMan98
« on: June 11, 2017, 05:00:07 AM »
Help, I replaced my entire system, but the new water pump will not stop leaking, bottom lefthand corner, removed it ten times all looks good, large o ring is seated in as it should, what I am I doing wrong
indybobm
Franklin, Indiana VRCC # 5258
« Reply #1 on: June 11, 2017, 06:12:17 AM »
Are you sure that it is leaking from the water pump. Common leak is from the upper radiator hose where it attached to the thermostat housing. Tightening the hose clamp usually fixes that.
So many roads, so little time
VRCC # 5258
ValkyrieMan98
« Reply #2 on: June 11, 2017, 06:55:12 AM »
Thanks, I also replaced the upper hose, I also thought that and went back and retightened it, I also did a test, I wrapped a rag around the top and ran the engine, still leaked out of bottom bolt, I have it off on 10 times I am at my wits end
bikerboy1951
Grand Forks, ND
« Reply #3 on: June 11, 2017, 07:06:17 AM »
Is the little copper seal on the bolt?
Brad
ValkyrieMan98
« Reply #4 on: June 11, 2017, 07:24:34 AM »
that i am not sure I will ck
thanks
ValkyrieMan98
« Reply #5 on: June 12, 2017, 11:09:57 AM »
Final
This was not fun, I removed the water pump at least a dozen times, the final time, Yep Snap goes the top left bolt, had to be the hardest to drill, after about 10 hrs drilling taping, praying  I used a 5/16 std course and finally no leaks, never want to touch another water pump.
Thanks for the help guys
