J.Mencalice
« on: June 14, 2017, 07:03:17 PM » |
« Last Edit: June 14, 2017, 07:06:38 PM by Jmencalice »
Wizzard
Bald River Falls
Valparaiso IN
« Reply #1 on: June 14, 2017, 08:20:30 PM » |
Rode across the Mojave in 114 degrees,, it was not that bad. Wore a long sleeve white shirt and drank plenty of water. Better than cold any day.
 VRCC # 24157
msb
« Reply #2 on: June 14, 2017, 09:20:01 PM » |
lol...obviously "different strokes for different folks"  I have ridden in plenty of very cold & wet weather over the decades and as long as the roads are free of ice, etc I can handle that. Can gear up for cold and rain, but just can't gear down enough for 100+ degrees as far as I'm concerned, especially on longer road trips... it really shortens your day when you've got distances to go.
'99 Red & Black IS
« Reply #3 on: June 14, 2017, 10:00:01 PM » |
Had days in SOCAL and SOAZ where I Thought my A/C had died in my big truck BUT figured out It were doin ALL it could do. I was in Gila Bend Az one summer and the local radio station said at about 2 in the afternoon it was 123 Degrees F. When I pulled over to go inside at this little fuel stop opening the door of the cab the heat hit me like a hammer blow. IF I was riding in that neck of the woods with my breathing issues I'd hole up in the day and ride from sunset to sunup. The heat being "brutal" is generally an understatement and I worked a flight deck in the waters off Nam. RIDE SAFE.
« Reply #4 on: June 14, 2017, 10:18:28 PM » |
Heat I can deal with - COld - I just can't .
« Reply #5 on: June 15, 2017, 12:17:26 AM » |
Ill be passing thru Montrose and Mexican Hat next month.
« Reply #6 on: June 15, 2017, 02:00:23 AM » |
I enjoy being the only lunatic motorcycle enthusiast on the road when the temps dip below 40 and below freezing as long as the road is dry.
Commuting even on the police bike with the windshield down is not fun when it hits 85 or up as stop and go traffic sucks in full gear.
Give me a 50 degree day over 90 any time the bike even runs better in the cooler weather - at least it seems it to me
« Reply #7 on: June 15, 2017, 02:55:30 AM » |
i am with OSS, 40-50 over 90+ all the time.
Not so sure though below 35 degrees since here in WI much colder than that can get slippery. Coldest I have done is 34 degrees some 2 hours NO windshield and not planning on doing that again anytime soon.
I find Honda cycles overall have very good choke enricher systems unlike driving once a cold blooded carbed suzuki bike from the 80s way back when. Under 50 degrees it would NEVER start full choke even when new.
« Reply #8 on: June 15, 2017, 04:52:42 AM » |
Last week we had a high of 89 and welcomed the "cooling" trend. Sunday is suppose to hit 118. "Happy Father's Day"
Hooter
« Reply #9 on: June 15, 2017, 11:25:59 AM » |
Ditto on what OSS said. For the last week or so, even now, don't think coming north will give you much relief. Hotter than hell here and I haven't been riding much either. Riding when it's cool or even a touch cold is fine. I ride until there is sand and salt on the road.
I can dress to ride when it's cold. In the heat I won't ride in shorts like you see so many do. That's just foolish. If I do ride when it's hot out its in the evening. The only thing moving other than me in the evening are the deer, deer 30. I'm a little more careful then as well
RP#62
« Reply #10 on: June 15, 2017, 11:44:54 AM » |
I've found that above 108°, you're cooler if you're not moving.
-RP
« Reply #11 on: June 15, 2017, 02:37:26 PM » |
-RP
LOL! I had marked it at 106 but I'm sure you are more accurate. 90 - 95 degrees (F) is my preferred riding temp but I do like to keep moving.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #12 on: June 15, 2017, 04:46:14 PM » |
Above about 90º I like to wear a longsleeve, heavyweight mock turtleneck shirt which I wet down every hour or so. I wear a ¾ length mesh coat over that. It keeps me quite cool (low humidity) for 45-60 minutes. I also roll up a 32oz cup of ice cubes in my oversize (27") bandannas and wrap it around my neck. It will stay for a couple of hours even in 100º+ temps.
czuch
« Reply #13 on: June 15, 2017, 10:17:50 PM » |
115 Monday. Get wet. Inside and out. I ride all year (not so extreme here) and helmet every time. UV gets me bad,,, BAD!!! Dutch, Irish base. My people aren't from here.
« Reply #14 on: June 16, 2017, 04:14:51 AM » |
First ex Wife from Alaska. We moved to East Texas and the first summer there hot humid and sticky I was on the back lawn in a chair under our Pecan tree having a cold one when she quipped-Well least ways you can't shovel heat!  Damn near choked on my beer!  RIDE SAFE.
Valk-Obsessed
« Reply #15 on: June 16, 2017, 07:48:36 AM » |
It's a "dry heat" out west...  Still it's better than riding around in an uparmored HMMWV, with no AC (my unit didn't have the ones with AC until 2008) in 130+ with all the associated gear I used to have to wear... On the opposite side of the coin, I've ridden low 30's and geared up like the Michelan Man, and was hard pressed to enjoy that very much...thank goodness for heated gear!
« Reply #16 on: June 16, 2017, 03:21:57 PM » |
It's a "dry heat" out west...  Still it's better than riding around in an uparmored HMMWV, with no AC (my unit didn't have the ones with AC until 2008) in 130+ with all the associated gear I used to have to wear... On the opposite side of the coin, I've ridden low 30's and geared up like the Michelan Man, and was hard pressed to enjoy that very much...thank goodness for heated gear! Thank you for going in harms way and Welcome HOME.  Even though HOT the flight deck had one saving grace at sea-there wuz ALWAYS a good breeze blowin.  RIDE SAFE.
