February 13, 2026, 09:00:44 AM *
Author Topic: Fuel Line Length… Silly but true… process of elimination… diagnostic  (Read 1108 times)
Whiskey Bravo
« on: June 14, 2017, 05:16:54 PM »
Hello everyone,
Could someone kindly give me the fuel line lengths … I'm looking for the exact lengths…
2 4 6 side– carbs to T
1 3 5 side – carbs to T
And from T to the Petcook
thanks again
Whiskey Bravo
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: June 14, 2017, 07:04:42 PM »
If you are going to replace old lines, just cut the new ones using old ones as a pattern. Fuel line comes by the foot.
« Reply #2 on: June 14, 2017, 09:49:48 PM »
Actually, the fuels lines (if we're talking OEM) are some of the only tubing that comes in the correct length and not by the foot.
« Last Edit: June 16, 2017, 05:09:18 AM by Hook#3287 » Logged
Whiskey Bravo
« Reply #3 on: June 15, 2017, 02:11:39 AM »
Hello again everyone,
Thank you for the responses
However, I need the exact hose lengths…
Someone has been in the carbs/fuel lines and changed  the length … Thus, I am attempting to chase down issues systematically
I want to eliminate any possibility of poor fuel gravity flow to the carburetors…
Therefore, my question for exact length of the fuel lines
Can someone please chime in
Thank you again
Whiskey bravo
« Last Edit: June 15, 2017, 02:19:02 AM by Whiskey Bravo » Logged
« Reply #4 on: June 15, 2017, 04:04:56 AM »
Thank you again
Whiskey bravo
I'm too lazy to go out and pull the tank to measure. But if you have fuel line and clamps already. Just make them as short as you can and will still fit.
« Reply #5 on: June 15, 2017, 06:23:25 AM »
To bad I didn't read this post earlier, as we had NewValker's tank of yesterday to replace a fuel line that had a in-line filter.  Suspected it caused fuel starvation.
Anyways, I have a new OEM main fuel line and it measures 8 1/2".  It also has a sleeve cover that protects it from chafing against the carb bracket it lays over.
I don't have a tank off at the moment, so you're on your own on the two lines after the "T".  You should be able to figure those out pretty easily.
If any of the lines are original, it might be good to have a new "T" ready in case the plastic is toast.  Probably not, but I had one fall apart on removal.
« Last Edit: June 15, 2017, 06:44:39 AM by Hook#3287 » Logged
Paladin528
« Reply #6 on: June 15, 2017, 07:49:25 AM »
what issue are you diagnosing?
« Reply #7 on: June 15, 2017, 09:48:03 AM »
When I redid my fuel lines the kit I received from Honda had one side off the T that should be shortened a bit. AND I have NO idea where the bag is with that part #. BUT I did order it from Honda. Maybe 2 years ago when I desmogged. Plus on the install of the new fuel lines I did NOT use those little "clamps" they sent-had some small hose clamps in stock that I used instead. But I had my old lines to git the new lines right fer install. RIDE SAFE.
