February 13, 2026, 09:02:05 AM
Must be old age, my stem is drooping
Topic: Must be old age, my stem is drooping (Read 1423 times)
Mike M in ohio
June 14, 2017, 06:24:14 PM »
Returned from an 80 mile loop through the Adirondacks and noticed my front right directional light was dangling downward, hanging by the wires. It seems the stem separated at the seam beneath the black band that covers the connection. I can slip them back together. (there is about a quarter inch overlap. But the connection will not hold, and I don't see any kind of set screw or system to hold things together firmly. Has something cracked? Has an item disconnected and dropped off? Any ideas would be helpful. Mike in New York
Re: Must be old age, my stem is drooping
June 14, 2017, 07:19:17 PM »
Does this help?
http://www.ronayers.com/oemparts/a/hon/506cb674f870023420a41853/turn-signal-1
Mike M in ohio
June 15, 2017, 07:04:35 AM »
Actually, the schematics are a help. It looks like the tab that goes into the inner stem is broken off. (perhaps, tightened too much at some point) So, I cant secure the connection with the set screw. I;ve put it together with goop, and a loop of electric tape (which blends into the black rubber sleeve) It seems secure and the flexible silicone Goop will allow it to be pulled apart in the future. If it doesn't hold, I'll order the pieces and replace. Thanks. Mike
June 15, 2017, 07:50:58 AM »
A liberal schmear of goop can work wonders!
June 15, 2017, 09:25:24 AM »
Quote from: Britman on June 15, 2017, 07:50:58 AM
Sounds disgusting, but if it makes your stem stiffin up might be worth a try
June 15, 2017, 10:16:47 AM »
I hate when that happens.
Reply #6 on:
June 15, 2017, 11:31:02 AM »
Quote from: Jess from VA on June 15, 2017, 10:16:47 AM
Not to worry. Levitra, Cialis, Viagra is readily available.
Reply #7 on:
June 15, 2017, 04:24:41 PM »
Quote from: meathead on June 15, 2017, 11:31:02 AM
Not to worry. Levitra, Cialis, Viagra are readily available.
Man, you know girls with strange names.
Reply #8 on:
June 15, 2017, 05:01:39 PM »
Quote from: Jess from VA on June 15, 2017, 04:24:41 PM
