February 13, 2026, 11:59:58 AM *
Author Topic: engine heat distribution  (Read 1633 times)
turtle254
Livingston,Texas
« on: June 20, 2017, 02:13:47 PM »
does the left side of the engine get hot first on start up, I mean really hot to the touch?
« Reply #1 on: June 20, 2017, 02:46:42 PM »
If one side of the engine gets way hotter than the other faster at start up, that sounds like a problem to me.
turtle254
Livingston,Texas
« Reply #2 on: June 20, 2017, 03:17:08 PM »
Any ideal what it might be, because it does.
Anyone know of a good shop around Houston, to do a tune up on the carburetor's
« Last Edit: June 20, 2017, 03:19:53 PM by turtle254 » Logged
« Reply #3 on: June 20, 2017, 03:25:02 PM »
If you want help you have to help us!  How long have you had the bike, new problem?  Checked coolant?  Recent maintenance? How many miles?
Roidfingers
Tuscaloosa, Alabama
« Reply #4 on: June 20, 2017, 03:31:56 PM »
Year make model? Are you mechanically inclined?
« Reply #5 on: June 20, 2017, 03:51:31 PM »
Lol. I guess I assumed we were talking about a Honda Valkyrie
turtle254
Livingston,Texas
« Reply #6 on: June 20, 2017, 04:09:29 PM »
1998 standard  Just got it ... has been sitting up for awhile
5700 mi only . Ran techron cleaner thru carbs, and runs fine
does not show cooling light on. After awhile both sides or hot.
Just thought it was strange one side got hot long before the other.
Maybe all Valkyrie do?
mrgeoff
My 99 CT..."Liahona"
Augusta, GA.
« Reply #7 on: June 20, 2017, 04:51:30 PM »
Just a thought...I think if it was me, I would flush out the radiator...Just remember that when you get ready to put in new antifreeze, use distilled water to flush out before adding antifreeze...!!!
Hope it is this simple to solve your concern...!!! Good Luck...!!! And let us know what you find...It helps everyone here...!!!
mrgeoff/SANDMAN
Pete
« Reply #8 on: June 20, 2017, 04:52:45 PM »
Check the choke (enrichner) 1 side may not be working right (broke cable, mal adjusted). In this case usually the right side is not enriching and the left is. Left hot, right warm.
« Reply #9 on: June 20, 2017, 05:04:43 PM »
No. Probably partially clogged jets or bad choke linkage.
« Reply #10 on: June 20, 2017, 05:04:58 PM »
While cold remove the left side cover and the radiator cap. Fluid should be up to the top at the radiator and at the cold line in the overflow container.  Be careful not to open (like a door) the side cover very far or you will break the mounting tabs.
« Last Edit: June 20, 2017, 05:06:41 PM by Chrisj CMA » Logged
turtle254
Livingston,Texas
« Reply #11 on: June 20, 2017, 05:35:36 PM »
Checked choke and fine (no choke used in texas right now), so if both sides are to be the same in warm up stage, then I must have a carb problem.
Moonshot_1
« Reply #12 on: June 20, 2017, 06:00:47 PM »
Not a mechanic. Reading the posts. Have a question.
Are you sitting on the bike when you start it up or is the bike on it's side stand?
I am assuming the bike is running well in all other respects, correct?
If on it's side stand when at idle, I would tend to think the hot oil would pool on the left side. It would circulate through the engine but the now hot oil in the pan would pool towards the left making the left side heat up a bit faster because there is just more hot oil on that side.
To me, the fact that you noticed this at all would indicate the bike being on the side stand.
When I start my bike I'm well on the road before it can heat up too much. I wouldn't notice such a heat difference unless my bike was running without me on it and on it's side stand.
Mike Luken
Cherokee, Ia.
« Reply #13 on: June 20, 2017, 06:06:03 PM »
Also the rad cap has a lock screw, mark sure it's loosened before you forcefully turn it.
I think you need to clarify how long a long time is?
Like Moonshot, I would never notice, I'm out riding 10-30 sec later.
« Reply #14 on: June 20, 2017, 06:23:43 PM »
Probably, but it would still be a good idea to remove the chrome carb linkage covers and check that the linkage is working both sides equally.
turtle254
Livingston,Texas
« Reply #15 on: June 20, 2017, 07:39:18 PM »
Done that(choke linkage) ... bike is up right in chock, also exhaust is much hotter
on left side.
« Reply #16 on: June 20, 2017, 08:17:43 PM »
There was a post a little while back of the float springs being weakened on the left side due to the lean of the bike. It let the floats not shut off fully. Could be that's what's going on here. I'll see if I can find the post.
« Reply #17 on: June 20, 2017, 08:29:45 PM »
I misremembered it a little. But here is the thread. Down about half way Leathel describes the issues with his left side carbs. May not be your issue, but worth looking in to.
http://www.valkyrieforum.com/bbs/index.php/topic,93751.msg946332.html#msg946332
Tfrank59
'98 Tourer
Western Washington
« Reply #18 on: June 21, 2017, 08:18:22 PM »
 That's good Meathead, clearly this has something to do with the lean of the bike on the side stand. There's also a thread in here somewhere about it smoking a little bit more on the left side due to the lean. Although my first thought was the guys were on track about the choke linkage but I guess it checks out.
-Tom
