February 13, 2026, 10:24:54 AM *
Author Topic: Quick question - leaking intake  (Read 894 times)
Dagwood
Grand Haven, MI - Chiefland Florida
« on: July 01, 2017, 08:20:49 AM »
Have the telltale golden sign on the block of a leaking intake on number 3. decided to do a desmog today and things are going great thanks to the writeup here and redeye. Since I have the airbox off and am going to replace all the intake o-rings, can i just pull all the bolts to the intakes and raise the entire carb bank to do all the o-rings at once? Looks like I can from here, appreciate the help!
Youth and Skill are no Match for Age and Treachery
Steel cowboy
Spring Hill, Fl.
« Reply #1 on: July 01, 2017, 08:32:21 AM »
Totally remove all the intakes first. Gives you a lot more room.
2001 black interstate
2003 Jupiter Orange wing
Harryc
Sebastian, Fl
« Reply #2 on: July 01, 2017, 01:21:33 PM »
Yeah but you need to get underneath the intake tubes to remove and reinstall the new o-rings. I just pulled them off one at a time. Use some silicone grease to hold the new o-rings in place upon reassembly. Don't over-think it, this is an easy job Wink.
Dagwood
« Reply #3 on: July 01, 2017, 01:32:38 PM »
Thanks guys. I did raise one side at a time and remove the intakes one at a time, cleaned them up, replaced the o-ring and reinstalled. No silicone was needed they all held until I bolted the intakes back down. Just need to deal with the airbox and should be good to go.  cooldude
