February 13, 2026, 10:41:20 AM
Need advice: Cobra Driving Lights lens gasket
Topic: Need advice: Cobra Driving Lights lens gasket (Read 1056 times)
Kunkies
Charlotte, NC
July 03, 2017, 04:43:35 AM »
Installed Cobra driving lights about a year ago and had to replace one bulb. I vaguely recall the gasket between the housing a lens, yet didn't replace. After the job was done I noticed a very small amount of light leakage from the seam on the housing.
Since, I have driven about ~2,000 miles and I always leave the driving lights on (for safety). The replacement bulb just bit the dust and I was surprised it went so quick. I think the culprit is no gasket allowing excess vibration and more importantly, moisture to sneak in.
I have no replacement gasket. Any suggestions on what to use? A friend told me to just use a liquid gasket, yet sounds messy.
Re: Need advice: Cobra Driving Lights lens gasket
July 03, 2017, 05:41:16 AM »
I have one complete Cobra light with eyebrow. The gasket is broken, but if installed carefully it works fine. I have never had a bulb fail except the one that took a rock.
Pm your address and Ill send the whole thing to you if you cover the shipping which should be rather cheap
