December 18, 2025, 11:13:03 AM *
Author Topic: Epoxy test video  (Read 1880 times)
SideCar
Bikers don't need shrinks!
Colleyville, TX
« on: July 03, 2017, 04:42:30 PM »
Found this interesting, especially with regard to the quick set
https://youtu.be/XObmZIbHOzY
BnB Tom
Where'd old times go?
Frisco, TX
« Reply #1 on: July 04, 2017, 05:25:20 AM »
I'm sure Valkpilot will be very interested in this demonstration..
  After all,  it answers one of his biggest questions -- "What does the data say?"  cooldude
Valkpilot
Corinth, Texas
« Reply #2 on: July 05, 2017, 07:15:13 AM »
I was, and it does:
JB Weld Original and the Devcon Plastic Steel appear to be the clear overall winners.
As is almost always the case in materials engineering, it also illustrates that when you customize for a particular attribute, like quick-cure or heat resistance, you usually compromise in other areas.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
