February 13, 2026, 10:41:20 AM *
Author Topic: In the middle of desmog.....have a question.  (Read 975 times)
ValkScout
« on: July 07, 2017, 09:25:38 PM »
https://goo.gl/photos/bvNkYySmbD1ezAbK6
https://goo.gl/photos/maFPMgnhgiWnPMig6
Sorry for the links, I was too lazy to set up a photobucket account after working in the garage all day! I'll do that later.
So, now my question for those with insight. I've done all the hard stuff for the desmog. It went well. Sure glad there is Youtube! So, in the pictures, the largest hose that would normally be attached to the bottom end of the air box. With the desmog kit I have, on the bottom of the airbox, that port gets plugged. So, what the hell do I do with the hose in the picture? There wont be enough room for the plug and that hose to occupy the same place. Is it safe to remove, or leave it? The second picture shows the module the hose is attached to, that is also attached to the breather hose for the crank case im guessing.
All the desmog info that i've read so far, never mentions what to do with this left over stuff. Any help is greatly appreciated.
Thanks everyone!
« Reply #1 on: July 08, 2017, 05:50:07 AM »
IIRC I did not disconnect the crankcase breather. To me the desmog eliminates the pair valves connections, and the vacuum lines and plugs them. I didn't use a kit however.  Used one of the docs in shoptalk for guidance.
« Last Edit: July 08, 2017, 05:51:45 AM by MarkT » Logged
